CRG lever vibes - Wrist Twisters
post #1 of 3 Old 05-28-2012, 09:29 AM Thread Starter
Doing things the hard way
kodiak919's Avatar
CRG lever vibes
My CRG levers vibe quite a bit, especially on the clutch side. Any ideas on how to reduce that?
There is a little play in there... would a washer help? wave/spring washer? Leave it alone you are being picky? Crazy Glue them in (JK)?
Setup:
2005 919
Renthal UL
CRG shorties
Motovation bar ends
Rizoma mirrors
Thanks in advance.
"No matter where you go, there you are." - Buckaroo Banzai
kodiak919 is offline
post #2 of 3 Old 05-28-2012, 11:24 AM
yes, find a way to shimmy them if you can to take up the excess slack. a washer, or a piece of plastic or rubber, something thin enough will be key, but soft enough to not score your lever. let us know what you come up with!
post #3 of 3 Old 05-28-2012, 12:39 PM
First, remove the lever pivot bolt and grease the living daylights out of the whole pivot assembly. If the vibration goes away just keep it thoroughly lubed and you're good. In any case more lubrication is usually preferable to less, so what do you have to lose?
The best way to take up free play is to find a piece of thin felt (synthetic works here as well), cut it into a washer shape, thoroughly work in some general purpose grease, and then see if it can be worked in between the lever and the lower face of the perch without damaging it or causing excessive drag -- the last thing you need in a lever.
I've even used a greased scrap of t-shirt for the same thing, but it shreds pretty quickly.
On the other hand you could just ride it and ignore the vibration.
robtharalson is online now
