coolant overflow in 55 degree weather? - Wrist Twisters
post #1 of 8 Old 11-01-2014, 11:01 AM Thread Starter
Garcia242's Avatar
So when I woke up this morning I noticed I had a small pool of coolant under my bike. It's obvious it came from the overflow vent tube. But not really sure I understand why. I changed the coolant several months ago. It was 55 degrees when I rode home early this morning. I would have expected this right after I changed it or in much warmer weather. Any thoughts?
my name is steve
i live in a box
my favorite color is clear
Garcia242 is offline
post #2 of 8 Old 11-01-2014, 11:11 AM
IIRC, If you follow the lines on the overflow it'll be over full. Since you are far enough south, just run water and the bike and you'll likely never notice
post #3 of 8 Old 11-01-2014, 02:00 PM
Lido's Avatar
Or maybe if you road it a bit hard just before you parked it you might get a few drops.
Lido is offline
post #4 of 8 Old 11-01-2014, 02:03 PM
your fine. id be willing to bet all it was, was some residual that got sloshed up into the tube n dripped out. i know that happens to me when im slinging her back n forth in the canyons ill stop and 1 or 2 drips will come out of the tube simply due to it getting sloshed up and in.
post #5 of 8 Old 11-01-2014, 10:59 PM
... just run water and the bike and you'll likely never notice
Eh, propylene glycol has some lubrication properties that will keep your water pump living longer than if you just use plain water.
Should at least use coolant for the lubrification - or water wetter or equivalent.
post #6 of 8 Old 11-02-2014, 10:39 AM
Always use some glycol... Its anti corrosion and lubercation properties will make for a long living cooling system. I wouldn't go below 25% glycol.
post #7 of 8 Old 11-05-2014, 07:37 AM Thread Starter
Garcia242's Avatar
Sticking with the glycol for sure. No more spots so no biggie.
my name is steve
i live in a box
post #8 of 8 Old 11-05-2014, 08:17 AM
I agree. It's happened to me several times and there isn't anything wrong other than slosh overflow from what I can tell.
