coolant - Wrist Twisters
 1Likes
  • 1 Post By CKutz_GO
post #1 of 19 Old 03-22-2016, 07:10 PM Thread Starter
CKutz_GO's Avatar
coolant
About to change my coolant and thought id check i have the right coolant.
I've got these 3 coolants on hand... I don't see silicate free mentioned anywhere...
So let me guess, can't use um?
CKutz_GO is offline
post #2 of 19 Old 03-22-2016, 08:30 PM Thread Starter
CKutz_GO's Avatar
another dumb question..
all the directions for refilling with coolant say in summary:
"fill it up at the radiator neck, fill up the reserve tank. start the bike and let idle, blip the throttle a few times, top it off and replace the radiator fill cap"
am i understanding you leave the radiator cap off during that procedure?
Isn't coolant gonna shoot out of it?
i read a post from rob saying to put some rubber over the radiator fill neck and hold it down with a gloved hand cause it will get hot.
why not just replace the filler cap? prevents air escape?
so far managed to drain the coolant and only lose a drop.. but i did drop the drain plug sealing washer into the bucket of coolant
CKutz_GO is offline
post #3 of 19 Old 03-22-2016, 09:28 PM
I use the Prestone Stuff on the left. Definitely don't use the Dexcool. Find a dumpster and throw that shit away! If you mix that with green antifreeze it will coagulate and clog up the system. Not sure about the WalMart stuff.
If you leave the cap off the coolant wont shoot out if you run it just long enough to get the air out.
post #4 of 19 Old 03-23-2016, 05:42 AM Thread Starter
CKutz_GO's Avatar
haha thanks Mike. I think the Dexcool might be what my car takes. It's a Saab so the GM spec makes sense..
CKutz_GO is offline
post #5 of 19 Old 03-24-2016, 11:02 AM
If you leave the cap in it can creat a vacuum when you blip the throttle and the air escapes. When the bubbles come up the amount of coolant should drop. Also some time when you start the bike and the water pump kicks in the amount goes down for you blip the throttle. So you don't want to creat a vacuum. Blip the trotted and squeeze the hose if you can fill it up to the neck and reap until no more bubbles come out.
07919Dave is offline
post #6 of 19 Old 03-27-2016, 07:59 AM
hondatech9's Avatar
Flushing my 20,000 mile coolant and refill using only the best.
hondatech9 is offline
post #7 of 19 Old 03-27-2016, 08:09 AM
hondatech9's Avatar
I'm a genuine honda parts only nazi. The fact that I've been a tech at our local Honda dealer has taught me many a lesson. But one being that if you own a Honda-keep it Honda. Most buy a Honda because they are reliable, so why tamper with that ?
post #8 of 19 Old 03-27-2016, 01:17 PM
I've always used Honda premix and never had any problems.
garyb900 is offline
post #9 of 19 Old 03-27-2016, 01:36 PM
I use the prestone on the left in your pic.
post #10 of 19 Old 03-27-2016, 03:01 PM
Where are you buying your stock Honda PAIRS block off plates?
post #11 of 19 Old 03-28-2016, 11:15 AM
Texas wristtwister
Hey, about how long does a coolant flush take y'all. I am fairly certain one has never been done on my bike and I have 21.5k miles. I won't have time to have my bike out of commission for a full day or two until julyish
Jonstrocity is offline
post #12 of 19 Old 03-28-2016, 11:41 AM Thread Starter
CKutz_GO's Avatar
you don't need anything special to do it. probably allow 2 hrs if you're slow like me. Search coolant change and you'll find some detailed threads.. but you're basically just lifting the tank, loosen drain plug, unclamp the hoses at the pump and dump them if you want (you'll get some more fluid out but if you're flushing it, it doesn't really matter). some time for flushing/siphoning the oveflow tank. refill it and you're done.
Jonstrocity likes this.
CKutz_GO is offline
post #13 of 19 Old 03-28-2016, 12:05 PM
It may have been done at 16k when the valves should have had their first check. I don't have the maintenance manual or the owners manual in front of me right now but it shouldn't need to be changed until the next valve check. Honda says to reuse the old coolant but just change it.
I too am a huge fan of keeping OEM parts and fluids in the bike. There might be better stuff out there or there might not be. But the Honda quality comes from all things Honda not just the engineering.
post #14 of 19 Old 03-28-2016, 12:14 PM
Texas wristtwister
I was probably going to go with honda coolant. Didn't know if there was a better option or not. It gets pretty toasty here in south texas, and I'd like to keep my temps down as much as possible
post #15 of 19 Old 03-28-2016, 12:25 PM
Distilled water is more than enough for a 919 in south Texas. Cheap too! Why would I do such a crazy thing? Because Ethylene Glycol has about 1/2 the heat capacity of water, even in a 50/50 mix you're looking at 75% of the heat capacity of pure water. It's a great anti-freeze, but since I see freezing temperatures for 4-12 hours at a time outside (very rarely in my garage) I don't see the point.
post #16 of 19 Old 03-28-2016, 01:36 PM
One night below freezing in your garage could change your mind awfully quick
post #17 of 19 Old 03-28-2016, 03:21 PM
You could also dilute it down to 30% and still have freezing protection. Does this really benefit a street 919 even in places that see 90-100* riding weather? Probably not.
post #18 of 19 Old 03-28-2016, 04:25 PM
Do not run straight water in your cooling system. You need some kind of lubricant properties added, whether it is anti_freeze, engine wetter. Etc.
I'm still on the original coolant with 46k on the clock, still looks new and clean. Granted. It's been filled partially at various times when I've worked on it. I will be doing my first flush with thermostat replacement soon.
post #19 of 19 Old 03-28-2016, 05:14 PM
I have never flushed mine. Just partial drain and refill when doing valve checks. Coolant always comes out pretty clear.
