Continued leaking fork seal - Wrist Twisters
post #1 of 18 Old 02-28-2014, 01:58 PM Thread Starter
No 10
insideleft's Avatar
I ()got my forks rebuilt a year ago or so - the suspension specialist altered the fork oil level to 110mm from the top, with springs out and fork depressed.
I () sold that bike for a newer 2007 hornet and changed the forks because the older one's had high quality springs, gold seals etc...
Two weeks after changing the forks, the left fork seal began leaking.
1) Changed both seals - 110mm fork oil - the left fork seal leaked again after two-weeks
2) Same as 1, leaked again.
3) Went to the shop, a trusted bike mechanic, who put new seals in, but only filled the fork oil to the factory level of around 140/150mm - to see if the 110 level was creating too much pressure for the seal to handle.
The bike 'suspension' mechanic (not the bike mechanic) had also advised used 5 dot fork oil because of the gold seals and we have persisted with this amount.
the left seal is now leaking again -
Mechanic's suggestion is to replace the upper fork, chromed, section - but he cannot say that this is actually the problem - $380 Australian and it may not be the issue - mechanic says he's never encountered this issue before.
A friend has suggested seeing if the bottom fork section has, somehow, become less circular and is, therefore, warping the seal.
I am beginning to pull my hair out with this ongoing guessing -
Anyone had, or know of similar calamities as this and what was done to problem-solve and eventually resolve such and issue ?
No10
No10
insideleft is offline
post #2 of 18 Old 02-28-2014, 01:59 PM
If you've put multiple seals on and it's still leaking, they you either have pitted tubes or bent tubes.
Time to look into that.
post #3 of 18 Old 02-28-2014, 02:32 PM
Excessive play could be a factor too, if the tubes look good. Did the bushings get replaced? Something else to consider if the other stuff checks out.
Superdog is online now
post #4 of 18 Old 02-28-2014, 04:51 PM Thread Starter
No 10
insideleft's Avatar
The mechanic's suggestion to replace the upper tube of the fork seems to coincide with the bent tube idea.
The tube is pitted, but far's I can see, only very high up the tube.
The bushes were replaced with the first set of seal replacements.
No10
post #5 of 18 Old 02-28-2014, 06:02 PM
Did you buy these forks from Wolf?
post #6 of 18 Old 02-28-2014, 06:47 PM
Total Awards: 17
If you've put multiple seals on and it's still leaking, they you either have pitted tubes or bent tubes. Time to look into that.
or if seals were not installed properly. Did they use lubed condom looking gizmo on fork tubes while sliding the seal?
zaq123 is offline
post #7 of 18 Old 02-28-2014, 07:39 PM
Seriously, what kind of seals have been fitted ?
OEM?
Or aftermarket ?
919s stock forks are known to be super dry past seals, too good if anything.
So IF it's a properly installed OEM still in good shape, it should be dry as a bone.
It's mechanicals and/or seal.
By the way, 110 is a high oil height.
Sure, there will be a range of opinions, but it's not lost on me that the Racetech build instruction sheet I got said go 140, and the local whiz I go to suggested 125 and sort of implied that was the upper limit. What are you trying to derive from using 110 ?
post #8 of 18 Old 03-01-2014, 01:40 PM
rpcraft's Avatar
LOL........ Sound the alarm!!!!
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #9 of 18 Old 03-01-2014, 08:22 PM
What, you mean cry "wolf"?
post #10 of 18 Old 03-02-2014, 02:23 AM
A decent wrench will be able to measure the roundness of the leg. If its round replace the seals with OEM ones. Grease them before fitting and re-grease them every few thousand ks. Fork seals are not a fit and forget deal. Regular greasing will make them last and keep you forks working properly.
NZspokes is offline
post #11 of 18 Old 03-02-2014, 04:05 AM
Low blow
post #12 of 18 Old 03-02-2014, 07:55 AM
Regrease what and how ?
Between the dust seal and the hydraulic seal ?
Between the two lips of the hydraulic seal ?
For sure the area between the lips of the hydraulic seal needs to be grease at installation.
919 seals seem quite insensitive to care.
Rickard has a set with original factory fill oil, something like 80,000 km or miles on them, I can't remember which, and they are bone dry.
Meanwhile, I clean my tubes before every ride, and they are bone dry.
post #13 of 18 Old 03-02-2014, 08:01 AM
Miles, 80k mikes. Never had a leak, hint of sweat or anything. I abused those things.
post #14 of 18 Old 03-02-2014, 10:41 AM
Hydraulic seal. Didnt you say you have sticton problems?
Procedure is, clean fork stauntion. Lift the dust seal. Clean under the dust seal above the oil seal. Get a lite dab of grease, quality axle grease seems to work best and run it round the area above the oil seal. Gently push down on the bars a few mm so you get a nice grease ring just above the seal. Then holding the front brake slam down on the bars as hard as you can. This causes the seal to flair and it grabs the grease. Wipe up residue and refit dust seal. Done. 5 min job that stops seal chatter.
If you look at a fork and see little rings of rubber on the stauntion just above the seal or you push down on the fork and its very slow to return (assuming you dont have stupid amounts of rebound adjustment set) then you need to grease the fork seal.
NZspokes is offline
post #15 of 18 Old 03-02-2014, 11:58 AM
Smile
Thanks for the added info.
I'm going to try it.
When it's not -25 C in the garage that is............
post #16 of 18 Old 03-02-2014, 12:03 PM Thread Starter
No 10
insideleft's Avatar
I'll try the grease idea, thanks.
The 110 height was recommended by the suspension specialist - I had the same leaking reaction at that height and the recently adjusted workshop manual height.
A friend will check the roundness of the upper fork tube, also suggesting this may be the problem - bike mechanic believes this is the only thing that can be a problem, that for some reason, the upper fork tube has become out out shape.
The right fork has remained not-leaking throughout all of the above, so it seems not to be the fork oil height, the seal type, the installation methods or anything else I can think of or that has been suggested above.
I'll fill you in on the greased fork tube.
No10
No10
post #17 of 18 Old 03-02-2014, 12:04 PM
Dont think my freezer even goes that cold.
About 75 here at 9 in the morning.
NZspokes is offline
post #18 of 18 Old 03-02-2014, 12:07 PM
No10
Sorry, grease wont help a damaged seal or out of round stuntion.
NZspokes is offline
