clutch replacement - Wrist Twisters
post #1 of 23 Old 03-07-2009, 04:29 PM Thread Starter
clutch replacement
ok here is the pressing question...
i want to know what all is involved in replacing the clutches in a 919... i also would like to replace the springs with heavier duty ones...
i am not having clutch problems...
i do not need to replace them
i have 6000 miles on the bike...
i am only thinking of doing this to make it absolutely bullet proof.....
i would want the heaviest duty/strongest....
soooo... what are the suggestions and the difficulty level of the replacement... (i have a high/very high level of aptitude)
post #2 of 23 Old 03-07-2009, 05:15 PM
LIVE FOR THE PROCESS
Nesty's Avatar
From the manual, looks like the biggest impediments are specialty tools you may need (centering, driver, etc) which show up in a couple of spots, and then just the manipulation of the clutch packs. And then, of course, is the typical STUFF I DID NOT RECOGNIZE IN THE MANUAL AS BEING A SHOW-STOPPING PAIN IN THE ASS.
Nesty is offline
post #3 of 23 Old 03-07-2009, 05:33 PM
Trackday Recognition Veteran
Quit messin' with the bike and just ride it...
Sokali is offline
post #4 of 23 Old 03-07-2009, 05:37 PM Thread Starter
i am serious... really i want to put in a heavy duty maybe kevlar or carbon fiber clutch... with heavy or xtra heavy springs....
post #5 of 23 Old 03-07-2009, 05:39 PM
For why?
Sokali is offline
post #6 of 23 Old 03-07-2009, 05:41 PM
I think at the most you prob would need to upgrade the clutch springs, the guy selling that supercharger kit for the VFR includes them with his kit and keeps the rest of the stock components, and that thing is putting down close to 160 at the wheel. But I could be wrong.........
post #7 of 23 Old 03-07-2009, 05:43 PM Thread Starter
Originally Posted by Sokali View Post
For why?
because......
its relatively cheap.....(under 100 bucks)
and i want it to be bullet proof.......
post #8 of 23 Old 03-07-2009, 05:46 PM
OK. If you think you need to. Remember it's a Honda...
Sokali is offline
post #9 of 23 Old 03-08-2009, 09:03 AM
3dcycle's Avatar
i have not done a clutch on a 919 before but plenty of other sport bikes it is not a problem. pick yourself a small peice of soft aluminum(4in long by 1in wide and 1/8in think) and wedge it between gears to torque it. or use a impact wrench to torque it.
the aluminum strip is a actual tool sent out by honda to "update" the clutches on the TRX450ERs and works really good. only good for a limited number of uses cause i gets all mashed up.
3dcycle is offline
post #10 of 23 Old 03-08-2009, 09:42 AM
Tirone shoelaces
TexasTraffic's Avatar
How reliable/durable is the OEM clutch on the 919?
I'm guessing the engine is over-engineered for 919 purposes - it was originally designed for CBR900RR purposes that had higher HP and RPM specs.
TexasTraffic is offline
post #11 of 23 Old 03-08-2009, 10:09 AM
Dude, toast the stock clutch first before even considering replacing it!
Now my Toyota 4x4...it NEEDS a clutch!
Superduke
R1200GS
XR650L
post #12 of 23 Old 03-08-2009, 01:14 PM Thread Starter
i am thinking about just the heavy duty springs... i really don't wanna toast it... i prefer to beef it up now instead of later...
post #13 of 23 Old 05-11-2010, 10:02 PM
Banned
^ I am 100% sure this is the issue with pressure plate/Clutch bearing and i am pretty sure i am right. The mountings will make noise when engine is idling once moving on plain road mountings rarely make any noise until you have a bad stretch of road or you are accelerating / deaccelerating rapidly . Also you must be feeling the clutch is not smooth .It is like heavy feel on the clutch pedal .
I do not know about wagonR but in M800 there is this thing (on Gearbox)on which clutch cable is mounted .Locally mechanics call it the jhanda/flag.Over a period of time it wears out and needs to be replaced .It makes a big difference in the feel of the clutch .I had it replaced at 1,00,000 kms on our M800 .
Chairs
winner2010 is offline
post #14 of 23 Old 05-11-2010, 10:11 PM
What's a 919?
RoboStraub 919's Avatar
I haven't replaced the clutch on my 919, but replaced them on my old 1980 CB900. I'm telling you, I bought regular springs and only replaced 3 out of the 6 and that clutch was stiff as shit for a more than 1k miles. I don't know what the modern CB919 s like, but if you're looking for ultra heavy duty springs, you might want to start exercising your forearms now.
I'm interested in how this goes though as my 919 has 26k on what is more than likely the original clutch and I'll be looking to replace mine in another season or two.
Slow is smooth, smooth is fast.
RoboStraub 919 is offline
post #15 of 23 Old 05-12-2010, 06:15 AM
^^^ You have a long way to go before wearing out that OEM clutch. Trust me.
post #16 of 23 Old 05-12-2010, 10:12 AM
ya op dont even worry about doing anything with the clutch... it grabs plenty hard ... hell someone on these forums had 77k miles on his stock clutch when he finally put his 919 out to pasture.
post #17 of 23 Old 05-12-2010, 10:16 AM
Honda Addict
razorbike's Avatar
Hasn't Bucky been running a stock clutch at the strip for quite a while?
From all the testimonials I've read the stock clutch is already pretty much bulletproof like the rest of the motor.
If it ain't broke, don't fix it!
If'n it were me, I'd spend the $ on some other mod.
razorbike is offline
post #18 of 23 Old 05-12-2010, 11:43 AM
i think bucky might of just replaced it.... but his got ABUSED with constant drag strip use, hard launches and NOS if im not mistaken..... and i think i remember him saying going right for the OEM clutch to replace the original one.
post #19 of 23 Old 05-12-2010, 05:43 PM
Yeah I am about 135K kms, whatever that is in miles. Still the original clutch.
post #20 of 23 Old 06-17-2010, 03:58 PM
Tiger1050's Avatar
You might consider just replacing half of them and give that a try.
If you replace them one at time you can forget about all of the extra steps taking the clutch apart. Just a thought.
Tiger1050 is offline
post #21 of 23 Old 06-17-2010, 05:04 PM
Gets censored
He's F'n with you guys.... Gotta be
If I'm mistaken (I may be I haven't been wrong yet this year and I'm due) try some barnett springs. I put some in a gsx-r way back. It was real stiff, ended up puttng 3 barnetts and 3 stockers felt good then. But thats before I relized there's no need for them on a stockish application.
brian is offline
post #22 of 23 Old 06-17-2010, 05:44 PM
Leave it alone, the OEM one is more than capable of coping with anything you throw at it under normal use. Spend the money on fresh oil instead.
Or send ME the $100 to my Paypal account and I'll post you a autographed picture of me wearing nothing but my motorcycle helmet.
now that's good value!
post #23 of 23 Old 06-17-2010, 06:10 PM
LOL, I needed a good laugh!
