Clank sound when ridding over a 1/2" bump. - Wrist Twisters
 1Likes
  • 1 Post By KarlJay
post #1 of 19 Old 12-09-2017, 07:21 PM Thread Starter
I've been screwing around with the rear shock by compressing the spring a bit more and now I'm noticing a clank noise going over something very small. Something like a 1/4~1/2" variance in the street like a tiny gutter lip, causes a noise in the rear.
Does the rear shock have a rubber cushion or is there some part of the rear suspension that would clank when hitting a tiny quick bump?
post #2 of 19 Old 12-10-2017, 02:50 PM
Can you get your bike up on a centre stand and check for play? Could be shock, wheel bearings or swingarm bearing.
post #3 of 19 Old 12-10-2017, 04:01 PM Thread Starter
No center stand, I've been able to balance it on the kickstand to adjust the shock spring. Kinda hard to check much that way. I can feel it, it's as if the shock was missing a rubber bushing and had a bit of play in it or something.
post #4 of 19 Old 12-10-2017, 04:41 PM
My stock rear shock is off bike. I took some pics of the end mounts. So you can see what's supposed to be there.
post #5 of 19 Old 12-10-2017, 08:08 PM Thread Starter
Ok, so it had a rubber coated eye. If that rubber is gone, it would cause a clanking. Damn, I'd hate to invest in a stock shock. I'm going to have to lean her on the side and wiggle that shock.
post #6 of 19 Old 12-10-2017, 08:52 PM
Actually that rubber you see is a dust seal. The metal centre piece is a collar/tube. Behind the rubber dust seal is a needle bearing.
File Type: png 30807fea42d4cee0fb530d8ea40ca242f3743d0b_1512967764793.png (118.9 KB, 11 views)
post #7 of 19 Old 12-11-2017, 03:00 AM Thread Starter
That would be strange if that bearing was bad, but I guess it could happen. Maybe I need to find a way to raise the rear while having the suspension hang free.
Maybe use the engine puller to life the back from the rear grab.
post #8 of 19 Old 12-11-2017, 03:36 AM
Yeah I can't really see that bearing going bad either. But it's worth a look even if just to rule it out.
I've lifted the rear of the bike before by using the grab handle. I suppose the only problem I can see would be stopping the bike moving from side to side while your yanking things around.
post #9 of 19 Old 12-11-2017, 08:47 PM
250xc-f
I have a 2002 with just over 10,000 miles and mine is making that sound as well. I thought it was the tool kit so I took it out of the bike, but that sound is still there. I really don't know how something from the rear shock could be worn out with that many miles, but I sure don't know what that sound is. Other than it is irritating.
250xc-f is offline
post #10 of 19 Old 12-12-2017, 02:17 AM Thread Starter
Glad to know it's not just me, but at the same time, there's just the two of us... So my main concern is safety and it seems like the only thing that could cause that noise would be the shock. What else could it be? Front swing arm connection?
It seems like it has to be a moving part of the rear.
post #11 of 19 Old 12-12-2017, 05:36 AM
250xc-f
I can't argue with you.
I have mine in my living room on a rear pit bull stand (7 degrees with 4" of blowing snow outside) anyway I'm going to get underneath and check for anything that might be loose....
When they were released I bought a new 1973 Honda CR 250 M Elsinore and after one season the swing arm bushings were worn out completely. I took it off and sent it to So-Cal to a shop, that I can't remember the name of now, and they replaced the plastic type stock bushings with bronze bushings. With all that said it was 44 years ago, (man I guess I am getting old) and it just can't be that these bikes have that problem ?
250xc-f is offline
post #12 of 19 Old 12-12-2017, 02:40 PM Thread Starter
The weather sounds fun I'm in California and it's 60's for the last few weeks and the forecast is for 60's and I just got in from riding all over town.
I'm not sure what would make the noise, but few are talking about it, so it seem rare.
My bike is my daily ride, so I can only tear it down so far before I have to stop.
post #13 of 19 Old 12-12-2017, 06:29 PM
250xc-f
KarlJay I envy you and your 12 month riding possibilities.
Do you have access to rec gas ?
I hate ethanol that the Obama white house now has in our gas.
Here in northern lower Michigan I can get rec gas at two different stations that are close to me, one at 90 and the other at 91 octane. I use nothing else in my 919 or my KTM 250 xc-f.
I am still searching to find this problem....
250xc-f is offline
post #14 of 19 Old 12-12-2017, 07:57 PM
Both of you, check your exhaust hanger before the up sweep on the under side. Its likely cracked or broken, making the clank sound.
post #15 of 19 Old 12-13-2017, 02:11 AM
250xc-f
Thank you Pvster.
I really appreciate your help.
I will check that hanger here shortly....
250xc-f is offline
post #16 of 19 Old 12-13-2017, 03:44 AM Thread Starter
I'm not sure what rec gas is. I remember someone telling me he had barrels of fuel that were marked with something because it had limited use. I don't remember how it was marked, maybe a die and scent.
Either way you slice it, California has some of the most restrictive rules. I've heard the CA blend gas adds a lot to the overall costs of everyone's gas.
post #17 of 19 Old 12-13-2017, 06:28 AM
Another thing to check is the muffler bolt.. Somehow I had one back out on me last year and didn't notice until I went to wipe off the exhaust cover and the whole muffler was moving around
post #18 of 19 Old 12-13-2017, 11:37 AM Thread Starter
Good point. I should start grabbing things and see what's loose. I did add some brackets a while back and then took them off, maybe something worked loose.
badmoon692008 likes this.
post #19 of 19 Old 12-14-2017, 10:07 AM
250xc-f
Rec. Gas is available here in Michigan right at the pump in many gas stations.
It has no ethanol and it is premium grade.
It costs maybe 10 cents more a gallon.
https://www.pure-gas.org/extensions/map.html
I have been under my 919 a number of times and the exhaust pipe mount is solid on both sides. Now it could be cracked right where the bolt goes through, but unless I loosen the system and take it off I will not know about it for sure. I have also checked both mufflers and their shields and they seem to be tight. I have searched my Honda Service manual looking at the diagrams.
Thanks badmoon and KarlJay
250xc-f is offline
