Changing bearings - Wrist Twisters
post #1 of 5 Old 08-02-2013, 03:39 PM Thread Starter
No 10
insideleft's Avatar
Changing bearings
I'm changing the wheel and rear chain wheel bearings on an '02 that I'm about to sell -
Any tips on:
tools you've found friendly ?
whether changing the bearing in the rear wheel chain sprocket bearing (???) is tricky or not ?
No10
No10
insideleft is offline
post #2 of 5 Old 08-02-2013, 03:42 PM
Ginger-prick
EatDirtFartDust's Avatar
They're pretty easy. I used a socket extender to ban out the old ones.
Then refrigerate the new bearings and tap them in by the outer race nice and easy.
2007 Honda 919.
EatDirtFartDust is offline
post #3 of 5 Old 08-02-2013, 04:14 PM
Did mine with a long drift punch and hammer, I didn't do the sprocket carrier bearing at the time but I will when I put the new chain on.
post #4 of 5 Old 08-02-2013, 09:05 PM
HotCarl73
HotCarl73's Avatar
i've used this from harbor freight to change bearings on about 6 motorcycle wheels now. works pretty good. seems to be sturdy enough. i did a few with punches and stuff from the other side. this works better.
Blind Hole Bearing Puller - Needle Bearing Puller
HotCarl73 is offline
post #5 of 5 Old 08-03-2013, 02:25 AM Thread Starter
No 10
insideleft's Avatar
Thanks,
Haa, refrigerate em - I'll do that, it sounds like an excellent idea - I was gonna buy a bearing puller kit, but lotsa fella's suggest using tools - the extension bit sounds interesting - I'll take a look at drift punches too - if they don't work, I'll def buy the puller kit.
The '02 is sitting being renovated, so I can play with it -
No10
