Chain Oiler for the Lazy - Wrist Twisters
post #1 of 23 Old 10-04-2009, 02:33 PM Thread Starter
I made a chain oiler setup for my 9'er that I've been testing out for a couple of thousand miles. For the most part it's totally unnecessary, but I like to tinker . So far its working good so figured I would post a few pics.
Here's the general set-up. It's gravity feed and I have been using it about every time I get gas (160-170 mi). The restrictor allows about 1 drop every 2-3 seconds. So far I have just been using regular 40W motor oil, but will try gear oil next.
The delivery to the chain is through a brush that is normally used in industrial applications to lubricate chains (I assume in manufacturing plants). The bristles are nylon and really soft (kinda like a paintbrush) so I don't think there is any danger to the o-rings, but I will continue to monitor.
The supply valve is just under my left leg on the side of the bike and I can reach it while riding with a little effort or just turn it on at a stoplight.
Under the seat is the Reservoir, made from 1-1/2" PVC and a few fittings...
...the charging valve and restrictor...
...and the Vent Valve...
Here's a wider view of everything under the seat
This is about what my chain normally looks like. I think this was about 50 or 60 miles after I used it.
So far so good. The nice thing about the brush application so far is that you don't have to worry about your speed. It puts and seems to maintain a very thin layer of oil to the rollers. I do get some fling mainly on the underside of the swing arm and inside the front sprocket cover, but too nothing annoying.
Total cost about $50. The brush was the most expensive and was $21. The rest of the pieces and parts were roughly $30 and found at Lowes.
post #2 of 23 Old 10-04-2009, 02:46 PM
McCrimmon's Avatar
Your that lazy you decided to become unlazy and make a chain oiler
j/k Interesting design Mike. Good on ya
2008 Yamaha FZ1-Street
2005 Honda CBR 600rr-Track
McCrimmon is offline
post #3 of 23 Old 10-04-2009, 02:46 PM
Alaska bound
fehren2800's Avatar
Donation Donation Extraordinary Ride
Nice job!
After many years and many dreams I have realized my goal of riding in all 50 states!
Now the rest of the world!
Every now and then go away and have a little relaxation. To remain constantly at work will diminish your judgment. --Leonardo Da Vinci
fehren2800 is offline
post #4 of 23 Old 05-07-2011, 03:11 AM
Survivor/Broken&Busted
yostevo052's Avatar
Community Service Veteran
Fixing to make one of these tomorrow .... just cuz I can lol .... and a good chain is frikkin expensive !!! ....
yostevo052 is offline
post #5 of 23 Old 05-07-2011, 03:36 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Very slick!
I'm interested in how much more chain life you will get by constant lubrication.
My chains last between 13k & 17k with a WD40 wipe down after every ride and periodic lubrication especially after rain.
Keep us posted.
Doc
ST-DocLizard1 is offline
post #6 of 23 Old 05-07-2011, 04:07 AM Thread Starter
I really like mine. Here's the link where I got the brush if you plan to go that route and haven't got one.
Product Detail | Applied.com
Originally Posted by ST-DocLizard1 View Post
Very slick!
Keep us posted.
Doc
I put the chain oiler on when I replaced the OEM chain. So far so good. 12K on my DID X-ring...still solidly in the green. No visible ill effects to the rings from the brush. I just wipe the chain down every 500-1000 miles and use the oiler for 5-10 mins every time I get gas. I did switch over to 90W gear oil and only have to refill every 3 months or so.
post #7 of 23 Old 05-07-2011, 07:56 AM
Tirone shoelaces
TexasTraffic's Avatar
Looks like it could be easily adapted to most any motorcycle.
Here's my test engineer showing
You have a business opportunity on your hands!
- Make it smaller so it does not take up most of the under-seat room
- Make it easier to refill; use something like a front brake fluid reservoir?
- automatic shut off when the engine is not running? (I forget stupid stuff like that. messy! )
I like the brush. Other systems I have seen use a small pipe to drip the oil directly on the chain; this requires very careful positioning. Your brush idea eliminates the need for user precision while keeping all the functionality. Nice!
Since I commute daily, I have considered an automatic chain oiler. Wiping the chain down after every ride simply is not an option. Regular maintenance, while I do it, is a pain. Also - oil is the factory recommended lubrication, not a spray lube.
I just thank the engineers for including the second trip meter; I set it to measure mileage since the last time I sprayed the chain. Otherwise I'd have to manually keep track of the mileage interval
TexasTraffic is offline
post #8 of 23 Old 05-07-2011, 09:58 AM
was that a feature in 02 models? if so how do I set it up?
Thanks.
joshpit2003 is offline
post #9 of 23 Old 05-07-2011, 10:26 AM
Thanks.
sadly no. in 04 they got adjustable suspension, clock, and 2nd trip meter.
post #10 of 23 Old 05-07-2011, 10:55 AM
BrokeRecord
Mike the differance between yours and mine, is I put my oil on the inside of the chain, one inch before the rear sprocket. I figured it would be less fling there. I still have my squeeze bottle on the left front fork tube. I changed the OEM chain and gears at 35,023 miles, and should have left the rear gear alone.
I also bought the Harbor Freight 24" caliper and center drilled the rear axle and the swing arm thru bolt, and ground the calipr tips to fit snug in the holes. Then lock down the caliper, and check the other side. Once a week or so, I get the caliper and recheck the bolt holes. I also safety wire my rear adjusters. The rear axle has NOT moved in 4,175 miles as of yesterday.
Mike gave me the idea of the oiler, ZaQ123 gave the H.F. caliper tip, and Rob the safety wire tip. All together will get you max mileage from your gears.
brokerecord is offline
post #11 of 23 Old 05-07-2011, 11:53 AM Thread Starter
Thanks for the comments Texas
1st Gen was a drip tube, but it seemed that only about 1/2 of the drips made it on the chain, most likely due to wind. I'm really happy with the brush. It also had a solenoid valve but it didn't last long (probably not very high quality), so I switch to manually operated. You just have to remember to turn it off.
Definitely room for improvement on the reservoir. Since I wrote this thread, I deleted the vent line and just made a fill cap in the top of the reservior. The reservoir could be much smaller, because it doesn't use the oil at a really high rate. There are alot of these type things used in industrial applications for lubricating chains. Including reservoirs and solenoid valves, but they are way too big to use on a bike.
post #12 of 23 Old 05-07-2011, 12:12 PM
Serial Monogamist
Total Awards: 21
Great thread, very ingenious idea, and good info from all respondents.
Doc
post #13 of 23 Old 05-07-2011, 07:58 PM
yostevo052's Avatar
Thanks !!! ... frikkin awesomesauce !!
post #14 of 23 Old 05-08-2011, 07:28 AM Thread Starter
Wow 35K on a chain is awesome. Were you using your oiler for part of that time and do you have a link to your oiler? I remember seeing but couldn't find the thread. I'd like to see how you positioned the outlet near the rear sprocket. The squeeze bottle is a great idea. Very simple, and you don't have to worry about forgetting to turn it off.
post #15 of 23 Old 05-08-2011, 10:48 PM
BrokeRecord
Pics should be on an older thread somewhere. I put mine on at around 1,000 miles and it's still hooked up. My oil dripper end was plastic, and it came loose and was ground up in the chain. I cut a new one outta 6061 and pressed in brass tubes in a Y shape. This was pop riveted to the bottom of the swing arm.
post #16 of 23 Old 05-09-2011, 01:11 PM
So, you're a human...
adamjayp's Avatar
Nice with the brush! I use the Loobman [LINK] which is similar, but puts the oil on the sprocket instead of the chain. Seems to work good for me. I use 90wt oil in mine.
I like the brush idea though... Interesting.
adamjayp is offline
post #17 of 23 Old 05-09-2011, 08:09 PM
schrock86's Avatar
Can you post up a pic. The ones on their website don't look the greatest.
schrock86 is offline
post #18 of 23 Old 05-09-2011, 08:48 PM
adamjayp's Avatar
I'm not sure I have one. Lemme see.
adamjayp is offline
post #19 of 23 Old 05-09-2011, 08:55 PM
i have run the scottoiler since the bike was new, I have 42000 km on the original chain, and still going strong, best $ saving mod there is IMHO
davehirt is offline
post #20 of 23 Old 05-09-2011, 10:14 PM
adamjayp's Avatar
Well, I thought I had some pictures of it, but I guess not. It's kinda taken apart right now (took the bottle mount off) but I'll get some pics of it when I get it put back together. It's kinda hard to photograph to be honest.
adamjayp is offline
post #21 of 23 Old 05-10-2011, 11:06 AM
Tirone shoelaces
42,000Km = ~26,000 miles.
Pretty good!
post #22 of 23 Old 06-05-2012, 04:47 AM
RMWL
SManZ's Avatar
Hey Mike,
Where did you get the restrictor and what are the specs for it? I bought my last 2 cans of chain lube. I'm determined to have a lubing setup on my FZ before I run through those!
Do you know of a cheaper alternative to the nylon brush? How many miles do you get between having to replace the brush? I was tossing in my head of getting a round paint brush, lopping off the handle, and feeding oil to the bristles with the clear tube.
-T
Hokey religions and ancient weapons are no match for a good .45 at your side, kid
2006 FZ1, Red & fully Ivanized
2008 YZF-R6, Raven, Mostly stock
2010 Toyota Tacoma, jacked & TRD Supercharged, 15mpg on 93
SManZ is offline
post #23 of 23 Old 06-05-2012, 05:46 AM Thread Starter
Originally Posted by SManZ View Post
Hey Mike,
-T
The restrictor I used is for drip irrigation that you can get at Lowes/ Home Depot. I think the one I got was rated for .5 gal/min. Keep in mind that flow rating is with 40-50 PSI behind it. With just static oil it was only about 1 drop every 30 secs. Whatever you use, test it before you put it on the bike.
As for the brush, I think I got about 20K miles out of it. It gets a little deformed and worn over time, but I didn't really care as long as it was still touching the chain. You could probably rig up something like you described, but I went with something that was designed to be used with a chain, plus it already had the port to hookup the oil tube to.
Good luck.
