Chain noise - Wrist Twisters
post #1 of 22 Old 11-07-2013, 06:27 PM Thread Starter
crimedog's Avatar
Chain noise
Hi all,
I'm stressing out over my 02 919 with 29k miles. I've only had it for 1k miles. Two rides ago I noticed some noise between 2500 and 3500 rpm. Sounded a bit like something was catching on the chain or scraping. I thought that it might be the chain so I readjusted it and now the chain is making a fair amount of noise towards the front sprocket. Sort of sounds like it's scraping the front of the rubber that protects the swing arm.
I have been taking the car while I try to fix this but I'd really like to get back on it. Any advice would be appreciated.
08 DR-Z400SM
WFOATT
crimedog is offline
post #2 of 22 Old 11-07-2013, 06:30 PM
If its the original chain, get a new one.
post #3 of 22 Old 11-07-2013, 06:40 PM Thread Starter
crimedog's Avatar
Are we talking replace it over the winter or don't take it to work you lunatic? Thanks for the response.
08 DR-Z400SM
WFOATT
crimedog is offline
post #4 of 22 Old 11-07-2013, 06:51 PM
It depends on how long it's been making noise. I've ridden on a sloppy chain for about 300 miles before. It made me nervous because you never know when it'll break. I'd just replace it ASAP if you are able. If not, bring it to a shop. If you do a search here, there's lots of threads on how to do it. I'm sure there's a video on YouTube by one of our most abusive mods.
post #5 of 22 Old 11-07-2013, 06:55 PM
Not knowing from your post if it's the original chain, I would also check your rear wheel bearings. Mine went out around 30K miles. Get the rear wheel off the ground and try to move the wheel back n forth. If it is the original chain, I would replace it as soon as you can if it's making that much noise.
marylandmike is online now
post #6 of 22 Old 11-07-2013, 06:57 PM
Are you measuring slack with it on the sidestand?
post #7 of 22 Old 11-07-2013, 07:04 PM Thread Starter
crimedog's Avatar
Hi all,
I don't know whether or not it's the original chain. I know that it's not too stretched out though because the adjusters aren't backed out all the way and I couldn't find any loose/tight spots when measuring at different points.
I adjusted and measured on the side stand and with the rear wheel off the ground and got about 1.5" when pushing up and pulling down.
08 DR-Z400SM
WFOATT
crimedog is offline
post #8 of 22 Old 11-07-2013, 07:15 PM Thread Starter
crimedog's Avatar
Thanks I will see if the wheel has play once I get the swing arm adapters for my rear stand.
08 DR-Z400SM
WFOATT
crimedog is offline
post #9 of 22 Old 11-07-2013, 10:45 PM
-Thread Lurker-
Mattaio606's Avatar
Haha you know what, Ive had the 919 for about the same time as you, and I noticed the exact same thing and was worried also. After looking at everything I came to the conclusion with the cold weather and rain recently that when I let off the throttle around that low range, or come to a stop at a light I would hear it. It was a few tight links in the chain and causing it to slap on the hugger- style chain guide. If its cold where you are, warm up the bike indoors and check chain links to ensure they freely move and do all the normal maintenance stuff. If someone was selling it, they may have put off the investment in a new chain/sprockets. Also, if your going to replace it, do the sprockets as well so ya dont cook the new chain
Till next time, Brrraap
Mattaio606 is offline
post #10 of 22 Old 11-08-2013, 03:31 AM Thread Starter
crimedog's Avatar
I guess a 17/44 520 conversion is in my immediate future. I don't want to spend the money but I plan to keep this bike for a long time.
08 DR-Z400SM
WFOATT
crimedog is offline
post #11 of 22 Old 11-08-2013, 04:44 AM
Your chin is too tight! You need to check slack with it on the sidestand with the wheel on the ground.
post #12 of 22 Old 11-08-2013, 06:36 AM
while sitting on it to properly gauge the actual tension... if I set it on the side stand it's piano wire tight when I (all 295 pounds of me) sit on it...
post #13 of 22 Old 11-08-2013, 08:04 AM Thread Starter
crimedog's Avatar
Any recommendations on chain tools? I'm looking at this kit:
AFAM 520 Sprocket Kit with the RK 520 GWX chain
crimedog is offline
post #14 of 22 Old 11-08-2013, 09:41 AM Thread Starter
crimedog's Avatar
I guess there aren't a lot of options if you don't want to spend a ton of money on the tool, I guess this looks pretty good:
Motion Pro 08-0470 PBR Chain Breaker : Amazon.com : Automotive
crimedog is offline
post #15 of 22 Old 11-08-2013, 10:00 AM
call LDH on the chain set, he had a smokin deal going on the set. the PBR chain tool works fantastic, worth the price
post #16 of 22 Old 11-08-2013, 10:20 AM
If you don't want to buy a tool and know how many links, you can have your local shop cut and rivet it. Installation is a bit more work but will save you some money.
post #17 of 22 Old 11-08-2013, 10:45 AM Thread Starter
crimedog's Avatar
oooh. I wanted to buy from him but the $20 shipping pushed me over the edge. Thanks!
I dont' mind doing the work myself, especially if the tool costs less than the install. Toolbox doesn't fill itself. Do 520 chains have the same amount of links as 530s? I'd assume so since but wanted to check that it would still be 112-114 links.
crimedog is offline
post #18 of 22 Old 11-08-2013, 11:36 AM
... I'm sure there's a video on YouTube by one of our most abusive mods.
Actually, our camera was stolen around the same time I replaced two chains, so you lucked out on this one.
And yes, 530 chains have the same # of links.
...on my Droid.
post #19 of 22 Old 11-08-2013, 12:23 PM
...on my Droid.
What makes you think I was talking about you? Sheesh. :P
Sucks that someone stole your camera. I hope you get/got a new one. Your videos are handy for many people.
post #20 of 22 Old 11-08-2013, 02:42 PM
Sucky thing was it was left in the FAMILY changing room at a local hot springs. We walked out and in less than 30 seconds it was gone. Some kids got a good lesson in how to plan for jail life in the next 20 years, that's for sure.
Stupid people.
I do have a ton of videos I need to get editing. Just haven't had the time.
post #21 of 22 Old 11-08-2013, 03:23 PM
Worst thing in the world is a thief. Fuckers!
post #22 of 22 Old 11-10-2013, 12:54 PM
+1!
Not related to the thread but related to the comment. I just recently had an incident where a thief stole a flashdrive from my stuff that contained sensitive client information. Put me into a world of hurt with state laws/procedures, ethics, program procedures, etc. Thankfully I was able to recover it with no questions asked even though the damage had been done. The graduate program took some responsibility in acknowledging that they contributed to us students being vulnerable by having to cart around all this information.
All it took was less than 30 seconds and that flashdrive disappeared.
