Chain and sprockets for the 919? - Wrist Twisters
post #1 of 11 Old 07-12-2012, 04:58 PM Thread Starter
Alright, i have done about an hour of pruzing through threads ect to see what people have said about chain n sprockets for the 919.
My requirements.... LONG LASTING ... thats it, i dont care about looks or weight saving.
That said, its obvious to me that DID 530 chain is the way to go... but which one?
And sprockets, steel obviously, but which ones.
I See this 530 DID VX chain, w/ steel sprockets for 200 bucks from sprocket center 530 Steel Sprocket Set w/Premium D.I.D. 530 X'ring Chain - HONDA CB 919 02-07 Sprocket Center and that seems to be the best deal i have found.
I HAVE PM'd LDH so im waiting to hear back from him on the subject. But i figured id ask the rest of the commuity what they thought and maybe some links to other deals / kits, Im not afraid to spend a little more if necessary.
Thanks Guys
post #2 of 11 Old 07-12-2012, 05:02 PM
Hastatus Prior
TheBeeDeeGee's Avatar
I got that same setup. I upgraded to the did chain rated for 1300 cc. No adjustment in 6k miles.
Sent from my DROID RAZR using Tapatalk 2
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #3 of 11 Old 07-12-2012, 05:04 PM
I'm very happy with my 17/44 from LDH, went with the superlite steel in the back. Another option would be SuperSprox, if you buy the counter, sprocket, and sealed (did or rk)chain they guarantee the sprocket for life.
http://www.supersproxusa.com/our_guarantee.php
post #4 of 11 Old 07-12-2012, 05:05 PM
Rich
RichT's Avatar
I bought the same setup also. Had to make a spacer to adjust for the different width in the cs sprocket.
Other than that, it seems to be working OK after about 5k miles.
RichT is offline
post #5 of 11 Old 07-12-2012, 05:44 PM
Veteran Donation
The main thing that is going to give your chain a long life is keeping it clean.A Good chain either 530 or 520 is going to last about the same amount of time.
The 919 makes good power ,but not enough to destory a decent chain if it is set up right (as in clean and adjusted correctly).
Let it stay dirty and any chain is going to have a very short life.
tvetree is offline
post #6 of 11 Old 07-12-2012, 05:57 PM
I have bought the sprocket center set-up twice. DID 530. Quality stuff.
post #7 of 11 Old 07-12-2012, 06:17 PM Thread Starter
yeah, im pretty anal about the chain lube and cleanliness.
Just trying to figure out the best quality : price : logevity ratio of chain and sprockets.
PS: i said anal lube and cleanliness in the same sentence!
post #8 of 11 Old 07-12-2012, 09:51 PM
I'd never go back to 530 from 520.
For max mileage I'd go steel rear instead of aluminum.
I have found the AFAMs and the DID to be excellent.
I think an o ring chain is more robust re long term seal integrity than x ring chain.
post #9 of 11 Old 07-14-2012, 06:41 PM Thread Starter
yeah im trying to figure out what i am going to do.... LDH is getting back to me on the details of his offered setup.
post #10 of 11 Old 07-14-2012, 07:24 PM
"CERTIFIABLE"
Ken Phenix's Avatar
For longevity, I'd stay with 530 simply because the sprockets and chain rollers have more surface area to distribute the load. All quality chains use some letter of the alphabet to signify the unique shape of their proprietary o-ring. All good. All hold the grease in. The key is tensile strength. Put a chain rated less than 10,000# on a bike with this much grunt and you're asking for premature stretch. I am currently about 10,000 miles into a new EK 530 ZZZ chain on the original sprockets. This chain boasts a tensile strength of 11,100# with a weight comparable to the average 520. The stretch thus far is minimal and even for the most part. Cheaper weaker chains will stretch unevenly. I clean with WD-40 and lube with Blue Label PJ-1 every 700 miles or so and after every sustained rain ride. Remember to spray at an angle so as to penetrate under the rollers - the only area that needs to be lubed on an o-ring chain.
I have also had excellent service out of SuperSprox sprockets on my last bike (4 rears and 6 fronts in about 100k miles) and will use them on the 919 when the time comes. However, please be aware that the lifetime warranty on their kit only covers the rear sprocket ring. You have to send worn unit off to have a new ring pressed on the hub. That spells down time and the RK or DID chain that comes with is usually more expensive. So I have found it's not really worth it to get the kit warranty. The solid black sprockets are the same material - just a little heavier.
Ken Phenix is offline
post #11 of 11 Old 07-14-2012, 07:44 PM Thread Starter
ya im definitely going a DID chain of some sorts.... the rest IMO are not worth it...
definitely not going with the SuperSprox sprockets kit.... way way to expensive for IMO a lesser product (chain wise)... though their sprockets themselves are priced pretty well.
