Chain adjustment questions - Wrist Twisters
post #1 of 11 Old 07-07-2013, 04:59 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
So I have adjusted the chain and now during inspection, while i roll the bike, at one point the chain is extremely tight and as I continue to roll the chain loosens. What is the problem?
2001 Honda Shadow
spyke1019 is offline
post #2 of 11 Old 07-07-2013, 05:07 PM
Probably time for a new chain. Is yours OEM? How many miles? Do you do maintenance?
post #3 of 11 Old 07-07-2013, 05:11 PM
It's binding in one or more places - to get around the front sprocket, the chain has to flex quite sharply to get around the corner - your chain doesn't want to do that, is resisting the bend, and as a consequence it's making the chain look tight temporarily. When that grumpy length of chain is in a straight line, between sprockets, the chain suddenly looks loose again.
K1w1Boy is offline
post #4 of 11 Old 07-07-2013, 05:15 PM
How old is the chain? Could be a kink somewhere or worn out. I would roll it around and inspect for kinks or missing o-rings. If you roll it to the tightest spot and adjust it, will it be way too loose in the other spot? If so, and you don't see anything obvious, it may be time to replace.
Good luck!
post #5 of 11 Old 07-07-2013, 05:38 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
No idea how old it is, but the p/o is my brother's brother-in-law, i'll find out about that tomorrow. I've got a 8 mile ride home, is it safe to ride like it is? There's nothing more I can do for it tonight.
post #6 of 11 Old 07-07-2013, 05:51 PM
Ride slowly and carefully if you have to...
post #7 of 11 Old 07-07-2013, 05:51 PM
I would be ok about riding it, yes, with a degree of caution...Have you got some lube you can spray on it at the moment, to help it along?
K1w1Boy is offline
post #8 of 11 Old 07-07-2013, 05:56 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
I've got white lithium grease, which is what I use anyway.
post #9 of 11 Old 07-07-2013, 06:01 PM
Ok, well, I'd smear some on, and head off, taking it easy and sticking close to the kerbside, just in case.
K1w1Boy is offline
post #10 of 11 Old 07-07-2013, 06:39 PM
It's probably not THAT serious...but on the other hand, a chain separation can do some serious damage! (Dangerous too).
Just try to avoid jackrabbit starts...take it easy on your way home and then make sure it gets fixed. It probably makes a clicking niose when you're riding along. Am I right?
Good luck!
post #11 of 11 Old 07-07-2013, 06:58 PM Thread Starter
Yo no sť nada
spyke1019's Avatar
Good luck!
No clicking, just a constant rattle from the chain. The whole time home I just kept thinking how big of a gash I was going to have from the chain exploding.
