Chain adjustment - Wrist Twisters
post #1 of 10 Old 12-05-2013, 01:14 AM Thread Starter
Chain adjustment
Y chain adjusters are almost at the end of their travel. Bike which is new to me has only 14k km on it. Is the chain stuffed or too long?
Don
mikkels is offline
post #2 of 10 Old 12-05-2013, 01:38 AM
Could have been ran too tight and stretched. How do the sprockets look?
...on my Droid.
g00gl3it is online now
post #3 of 10 Old 12-05-2013, 05:31 AM
It may have been one link too long when ot was installed. A lot of the OEM chains that came on 919's were that way.
post #4 of 10 Old 12-05-2013, 08:31 AM
...on my Droid.
+1
Seems way too fast for a chain to wear out. It may have been too tight or abused (never lubed), or just a link too long. The sprocket condition may tell the story.
post #5 of 10 Old 12-05-2013, 08:49 PM Thread Starter
Thanks all
Sprockets are ok.
Can you assess chain wear easily. What should I look for?
mikkels is offline
post #6 of 10 Old 12-06-2013, 04:09 AM
You can check the links on the rear sprocket to see how much play there is. This is a pretty good video:
Easy Motorcycle Chain Stretch Test - YouTube
post #7 of 10 Old 12-07-2013, 11:32 PM Thread Starter
That video was very good. Thank you. My chain is fine so I need to get the chain shortened as there is no adjustment left.
Thanks all for you help and advice.
Don
mikkels is offline
post #8 of 10 Old 12-07-2013, 11:38 PM
Give us a yell if you need a hand with anything on the bike. I know my way around them ok now.
NZspokes is offline
post #9 of 10 Old 12-08-2013, 07:17 PM
Canadian Blue
Mark919's Avatar
Don
Is the axle shaft actually all the way to the back of the slot?? And is there no adjustment at all left? My chain has always seemed on the long side and near the end of adjustment but, that was the way it was made, and it still does adjust with no issue. (It just doesn't need adjustment often at all.)
A long chain is also nice if you want to experiment with sprocket size changes (larger front or rear...)
Mark919 is offline
post #10 of 10 Old 12-09-2013, 11:24 PM Thread Starter
There is a little of the slot left but the bolts on the adjuster have only about a half turn to go to be fully wound in. Longer bolts would help a little but not much.
Don
mikkels is offline
