ceramic coating a Honda 919 header - Wrist Twisters
post #1 of 10 Old 08-03-2015, 04:51 AM Thread Starter
I'm looking into ceramic coating the header on my 919. I had the pipes done on my Harley (gasp) last year. I recall the guy stating that his blast media could get caught in small passages. Are there any obstructions inside the stock pipe that should be of concern? What about the Y pipe?
ray.beard is offline
post #2 of 10 Old 08-03-2015, 05:20 AM
The Y-pipe can have a catalytic converter in it, so that's an obstruction.
Shouldn't be any obstructions in the header. This isn't a poorly engineered Milwaukee product, after all.
post #3 of 10 Old 08-03-2015, 05:41 AM Thread Starter
Thanks for the info CB700S. The Harley is older so it would be imagineered in Milwaukee at best.
I tried to fish something through the header this morning and was unsuccessful. Obviously I can't see through the header with the upswing at the rear. I figured the ball in the center of the Y was likely a cat. I guess its best to leave that alone and just coat the header section.
post #4 of 10 Old 08-03-2015, 05:43 AM Thread Starter
Is the cat a California model thing or did it change in later years? My 919 is an 06.
post #5 of 10 Old 08-03-2015, 05:50 AM
Cats were included on later (post-mid-2002) 919s as Federal laws were changing. If you have a fat 'can' in the middle of your Y-pipe next to the inlet clamp, you have a cat.
Many earlier 919s had catted Y-pipes fitted by dealers after complaints of exhaust stink, so even early non-CA bikes can have one.
For sure, if you have *any* middleweight or heavier major maker bike made in MY2006 or later, you've got a cat thanks to Federal mandate.
post #6 of 10 Old 08-03-2015, 05:56 AM Thread Starter
I do have a bulge before the Y (TWSS). If I have a cat is there any reason not to switch the Y to an earlier cat. I have a feeling I'll be using the search engine tonight to do more research.
post #7 of 10 Old 08-03-2015, 06:19 AM
1. The earlier pipe is not available any more from Honda, who will only sell the next to last catted pipe (part 18380-MCZ-D12) for earlier models. That one came from the 04-05 California model.
2. 06-07 bikes have a slightly larger cat due to the 06-on standards. That one's 18380-MCZ-D13, no matter whether it was CA or not.
Here's the part number breakdown:
18380-MCZ-611 - 2002 to 2003 California emissions pipe
18380-MCZ-003 - 2002 to 2005 Federal emissions pipe
18380-MCZ-D12 - 2004 to 2005 California emissions pipe
18380-MCZ-D13 - 2006 to 2007 50-state emissions pipe
D12 and D13 are the only ones that Honda will sell any more. D12 is what the pre-06 bikes are supposed to use and D13 is what the post-06 bikes came with and are legally obligated to use. Interesting to note that there isn't a -000 version.
I have *heard* that the 02-05 pipe could sometimes be had with a bulge that had nothing in it, i.e., was catless from the factory. However, that does not match what I've seen - every single US market 919 'bulge' pipe that I've looked at has had a cat in the bulge. Euro models were different, of course, and they had no-bulge Y-pipes for some years, I don't know what the breakdown is for them.
I have a relatively early production bike (MY2002, 1500 series serial number); the pipe appears to be original and when I took the pipe off to check it several years ago there was a cat in the bulge. This is a 49-state bike that was originally sold right here in the Dallas area. I'm the third owner; the second didn't replace it (actually he didn't replace *anything* even though there were things he should have) and I can't get ahold of the first one. The dealership he bought it from and had it serviced at didn't have any records of the pipe being replaced.
Reasons not to switch: Exhaust stench will get a *lot* worse and you'll have more soot.
post #8 of 10 Old 08-03-2015, 10:57 AM
CKutz_GO's Avatar
about how much does it cost?
CKutz_GO is offline
post #9 of 10 Old 08-03-2015, 11:17 AM Thread Starter
I think I paid about $150 to do a pair of pipes for my Harley. The guy I used does headers for dirt track race cars (Zemco) as well as other coatings to race car drive line parts (Winters). He's located just south of Littlestown PA.
post #10 of 10 Old 08-03-2015, 12:04 PM
Brain stolen again?
You can contact these guys:
Jet-Hot Ceramic Coatings
Mathew Quigley
