cbr 954 rr doa ! - Wrist Twisters
post #1 of 3 Old 09-27-2012, 07:27 AM Thread Starter
cbr 954 rr doa !
Hey Guys
I new to these forums but I need some advice?
I have a real interesting problem with my bike. I have trying to fix it myself but have had no luck. they say two heads are better then one !
I have a 2003 cbr 954 rr that developed a crack in the water jacket. I bought a new case and swapped everything out fine..Got it all back together and now I have a no start problem.
I have checked all the wires,have a new ECM new main harness, and swapped the injector/tps rack.
The tps wires have good ground ,5 volts signal, and 0.50 volt reference.
here is the good part: I hook up my power probe to the battery, that gives the tip 6 volts, I back probe the signal wire(0.50 v ) that gives it 3 volt. the bike starts right up. runs great, but the voltage on the signal wire stays at 3 volt no matter where the throttle is. I disconnect the power or ground from the battery and it dies. any ideas would be greatly appreciated.
racerfan34 is offline
post #2 of 3 Old 09-28-2012, 02:08 PM
redline919's Avatar
Originally Posted by racerfan34
Hey Guys
Ok you said it doesn't start then you said it does so if it does....Sounds like a bad stator or regulator/rectifier. Your battery should be at least 12 volts probably a lil more. Get a service manual and check those parts. You will prob need a new battery unless it will take a full charge also.
redline919 is offline
post #3 of 3 Old 09-28-2012, 06:45 PM
+1. Stator or regulator/rectifier. You should be getting 13-14v at the battery when its running.
