CBR 900RR Header to stock Y pipe - Wrist Twisters
post #1 of 21 Old 10-17-2016, 03:10 PM Thread Starter
Question CBR 900RR Header to stock Y pipe
Hi Twisters,
I am trying to find out will the CBR 900RR headers fit the stock Y pipe on a 2002 CB 919?
My goal is to eliminate the cat but keep the undermount dual exhaust. Any assistance would be greatly appreciated.
Also will this header work with a belly pan or does it sit too low?
Thanks again for your time
AWP34 is offline
post #2 of 21 Old 10-17-2016, 06:04 PM
redline919's Avatar
Originally Posted by AWP34 View Post
Hi Twisters,
The 900rr header is for a side mount exhaust so it will not work with the y pipe without extensive fabrication. I've never seen a cat on a 919 before. Cali bike? Your easiest route is to pick up a header from a non California 919.
redline919 is offline
post #3 of 21 Old 10-17-2016, 06:52 PM
bartsitarski's Avatar
Post a picture of the cat. If you need a header, I have one that I can sell you. I am trying to purge some parts that I have laying around.
-Michael Jordan
bartsitarski is offline
post #4 of 21 Old 10-17-2016, 07:49 PM Thread Starter
Here are my headers from underneath. I don't think I have a CAT. Please correct me if I am wrong
AWP34 is offline
post #5 of 21 Old 10-17-2016, 07:57 PM
My 2007 had a CAT in the Stock Header. It was inside the bulges in the Y pipe. Here's a pic on the inside.
post #6 of 21 Old 10-17-2016, 08:02 PM
That looks just like mine. Went downstairs to check.
-Michael Jordan
post #7 of 21 Old 10-17-2016, 08:22 PM
The stock Y pipe of a 49 state 2002 does not have a cat to start with; unless you are in CA it is not even an issue.
My goal is to eliminate the cat...
Why? If it had one leave it, if it didn't don't sweat that either.
This. Those that have them have them there. If the Y is black= no cat. If the Y is stainless=cat.
Bryce919er is offline
post #8 of 21 Old 10-17-2016, 09:03 PM Thread Starter
Ok so here is my dilemma as my y pipe is stainless. I plan on getting the an exhaust as well as install my power commander and getting it all tuned. I was told by a tuner if I have a CAT that I would need to have a bung installed for an O2 sensor before the CAT which adds to the cost of this upgrade / tune. Any info would be greatly appreciated
AWP34 is offline
post #9 of 21 Old 10-18-2016, 04:48 AM
https://www.ebay.com/itm/162003192105
-Michael Jordan
post #10 of 21 Old 10-18-2016, 07:51 PM
There are many 06-07 (all have cats) or pre-06 CA models with slip-ons & PCIIIs that do just fine. I would not worry about it. If for some reason it bothers you it can be removed with a hammer & punch easily. It is in the bulge in the Y & looks like a bundle of very short drink mixing straws.
post #11 of 21 Old 10-19-2016, 02:35 PM Thread Starter
It's not that it bothers me. I was told a hole needed to be drilled before the CAT and a Bung welded/installed for the 02 sensor so that the PC3 and bike can be dyno tuned and mapped properly. Is this true?
AWP34 is offline
post #12 of 21 Old 10-19-2016, 02:46 PM
redline919's Avatar
No it's not needed
post #13 of 21 Old 10-19-2016, 08:35 PM Thread Starter
So do I go through the expense of dyno tuning? Or do I just load one of the maps in the 919 dropbox?
I will be running Scorpion Exhausts on my 919. I did not see any maps for the Scorpion slip-ons within dropbox. I do have my PCIII ready to install.
Your thoughts are greatly appreciated.
AWP34 is offline
post #14 of 21 Old 10-20-2016, 03:18 AM
Install it, run a map, see how it feels...
K1w1Boy is offline
post #15 of 21 Old 10-20-2016, 09:23 AM
redline919's Avatar
Depending on your elevation you can probably use one of the maps in the drop box. That's what I did. I think I'm using the 2nd Sato map from Ldh if I recall correctly. Try a couple out as stated. I looked for the bike to idle smoothly and the best throttle response. You are also supposed to sync the throttle bodies with the PC3 but I never did. My bike runs like a beast. No dead spots anywhere in the rpm range.
post #16 of 21 Old 10-20-2016, 01:04 PM Thread Starter
Sounds like a plan. Thanks
Can you provide link to maps? I have one drop box folder I accessed but not sure about whether or not LDH's maps are there
AWP34 is offline
post #17 of 21 Old 10-20-2016, 04:04 PM
redline919's Avatar
I'm pretty sure I'm using the satonew2 map here. https://www.dropbox.com/sh/r000mjqr9...19%20maps?dl=0
post #18 of 21 Old 10-21-2016, 08:38 AM
To the best of my knowledge, all of the LDH maps are in the McRomo compilation folder.
Including the moriv4 map as converted from original .map format to PC3usb required .djm format.
Also, many of the maps therein have been notated.
post #19 of 21 Old 10-21-2016, 08:47 AM
This is nonsense you are being told.
The 919 ECU can't handle an O2 input.
A PC3usb has no facility for an 02 input.
A tuner can use a wand up one of the pipe outlets.
You don't need a bung welded on and you don't need an 02 sensor.
Knock out the cat.
Synch the closed and open positions between the TP and the PC3usb.
Install a recommended map from the library.
(I always suggest moriv4 as the starting point for aftermarket twin canned factory header)
If that is not satisfactory, check to make sure your synch and map install was successful, then try another relevant map.
If you can't find satisfaction, and/or are fiendish about a custom tune for your specifics, get a custom map done by a good tuner.
post #20 of 21 Old 10-21-2016, 02:39 PM
A bit more on getting a custom map done.
919s have a high volume X low heat rejection area cooling system design.
While this is extremely rarely ever a problem (aside from high temp X low humidity X hi altitude air X sustained (or high time component of a track lap) high power levels, it can all too easily be problematic during mapping.
The 919 ECU (per LDH advice from eons ago and likely long forgotten by too many) has enrichening steps that kick in once the coolant temperature rises past the ideal range.
(my guess is the enrichening steps are intended to reduce combustion chamber heat load into the cooling system, noting power will also be reduced)
A 919 is into the fuel enrichening zone when the coolant fan kicks in.
If a 919 is being mapped while the cooling fan is on, the mapping will be incorrect, as the PC's mapping correction will be based on an enriched, and not normal, amount of fueling as called for the ECU's map. (remember, the map in the PC3 is a mapping correction laid over the ECU's map)
In other words, any part of a dyno run that is done with the cooling fan running, it botched.
And because of small rad and the large coolant volume, it takes longer to knock the coolant temperature down during the inter dyno run cool-off periods.
Today's tidbit : For track days, and IF your coolant is running hot because of above referred to conditions, remove the fan ! At speed, the fan restricts flow for the area it blankets and effectively reduces the heat rejection rate of the rad. Another trick is to run 10 % EG 90 % water along with WaterWetter. The 10/90 formula increases the specific heat of the coolant and improves its heat rejection rate of the overall cooling system. The 10 % EG content makes sure you have decent water pump seal lubrication, as hot water has very poor lubricating properties. If you want some antifreeze effect, use 25 % EG instead of 10, and keep in mind that 25 % EG isgood to roughly -10 F
AND won't actually freeze solid below that, and instead "slush up".
post #21 of 21 Old 10-23-2016, 11:42 PM Thread Starter
Thank you all for the awesome advice and pointing me in the right direction. PCIII has arrived. Now I am just waiting on my exhaust. I plan on removing the CAT in the meantime as exhaust is coming from overseas. Looking forward to seeing how the maps impact performance. Thanks again.
AWP34 is offline
