cb919 power dies at 5k rpm? - Wrist Twisters
post #1 of 14 Old 02-25-2009, 04:18 AM Thread Starter
my hornet has started to play up at 5k rpm and only in first gear. It cuts the power spot on 5000rpm for about half a second and then surges back, the harder i'm acelerating the bigger the jolt, this makes for a nightmare getting away from lights or junctions. Has any one had a similar problem or know what the matter is?
daleballgate is offline
post #2 of 14 Old 02-25-2009, 05:16 AM
do you have a power commander installed?
Ripper is offline
post #3 of 14 Old 02-25-2009, 05:26 AM
+1 on power commander possibly causing problems
Is it consistent at 5k rpms everytime?
post #4 of 14 Old 02-25-2009, 08:41 AM Thread Starter
nope ain't got a power commander instaled and it's always bang on 5000rpm and only in first gear. i.ve recently disabled the air box flap that seemed to ease it slightly, and there is a relitivly new air filter in as i thought it might be some thing to do with air flow but no luck as a cure.
post #5 of 14 Old 02-25-2009, 08:48 AM
Did this problem occur recently(perhaps after you or someone did work on the bike) or has it been that way since you bought the bike?
What year Hornet and what mods?
post #6 of 14 Old 02-25-2009, 08:50 AM
Heavy Metal
ratdog's Avatar
Air flapper vac line problem leak/problem
ratdog is offline
post #7 of 14 Old 02-25-2009, 10:12 AM Thread Starter
it's an 02 model with no mods, It started at the end of last yr (didn't use it much over the winter) i have had the bike for nearly a yr now so it was fine for 7 months. the problem dident start any time any other work was carryed out.
post #8 of 14 Old 02-25-2009, 10:18 AM
did it occur after installing the air filter? The air filter might be in backwards, but would explain why it is only at 5k in first.
post #9 of 14 Old 02-25-2009, 10:34 AM Thread Starter
nope i put the new filter in to see if i could solve the problem and it did nothing
post #10 of 14 Old 02-25-2009, 10:44 AM
Reconnect the flapper?
post #11 of 14 Old 02-25-2009, 11:26 AM
When you disconnected the flapper you did plug the vac. line didn't you? I've been known to forget trivial little things like that then spend hours scratching my head.
voodooridr is online now
post #12 of 14 Old 02-26-2009, 09:07 AM Thread Starter
919 losses power at 5k rpm
my hornet has started to play up at 5k rpm and only in first gear. It cuts the power spot on 5000rpm for about half a second and then surges back, the harder i'm acelerating the bigger the jolt, this makes for a nightmare getting away from lights or junctions. Has any one had a similar problem or know what the matter is? I disabled the flapper on the air box that has helped a little it has sofened the jolt a little. i have also put a new air filter on that has done nothing.
post #13 of 14 Old 02-26-2009, 09:20 AM
is this a double thread?? cause i swear this same guy started the same thread a couple days ago...
yep
post #14 of 14 Old 02-26-2009, 09:42 AM
hairball919
Guest
Posts: n/a
How ironic, because I started reading the original post and the replies, and was going to write "ask barton664, he would know!" and POOF!, there you are!
"barton664" translated means "919 God" (or sumpin like dat).
