cb599 engine locked up? - Wrist Twisters
post #1 of 13 Old 03-11-2014, 06:19 PM Thread Starter
redline919's Avatar
Ok so I picked up a 2006 cb600f roller with a title. I've been going over it trying to assess it. I want to know is there a way to turn the crank other than the sprocket to see if it's locked up? There is no chain. The sprocket bolt is loose. So I can't turn the motor over. Should I go on the other side and pop off the casing? I put a battery in but the starter isn't getting power just yet. I tried turning the sprocket by hand in gear. Not happening... Any ideas?
redline919 is offline
post #2 of 13 Old 03-11-2014, 06:21 PM Thread Starter
redline919's Avatar
I'd also like to add the back tire looks like someone did a big old burn out. Hope they didn't blow it up!
post #3 of 13 Old 03-11-2014, 06:33 PM
Not familiar with the 599, but on the 919 you can remove the timing cover on the right side and turn the engine with a socket wrench.
You should also be able to put a wrench on the front sprocket nut and turn it if the bike is in gear (assuming the chain is off).
post #4 of 13 Old 03-11-2014, 06:40 PM
+1
Yes do this
post #5 of 13 Old 03-11-2014, 06:45 PM Thread Starter
redline919's Avatar
Ok I will try it. I can't turn the sprocket bolt towards the front of the bike because its loose already. So I will try the timing cover. Thanks!
post #6 of 13 Old 03-11-2014, 07:28 PM Thread Starter
redline919's Avatar
Ya I think its locked up. Shit
post #7 of 13 Old 03-11-2014, 07:45 PM
Nickr919's Avatar
Dibs on the forkksss!!!!!!!
Nickr919 is offline
post #8 of 13 Old 03-11-2014, 07:58 PM
Nickr919's Avatar
All kidding aside you can prolly break that engine free... ive heard of pouring oil over the cams and into the cylinder and letting it sit for a while. So goes the story with an old suzuki 250 quad racer.
Nickr919 is offline
post #9 of 13 Old 03-11-2014, 08:06 PM
Fill the cylinders with diesel. It sometimes will free up seizures.
post #10 of 13 Old 03-11-2014, 08:28 PM
Dibs have already been called people.
https://www.wristtwisters.com/forums/...599-42617.html
post #11 of 13 Old 03-11-2014, 08:32 PM
Nickr919's Avatar
2nd dibs behind wolf.
Nickr919 is offline
post #12 of 13 Old 03-11-2014, 09:05 PM
Did you pull the plugs while cracking? Makes it easier when you aren't fighting compression.
...on my droid.
post #13 of 13 Old 03-12-2014, 01:38 PM Thread Starter
redline919's Avatar
...on my droid.
Nope. I will try that and what everyone else suggested as well. I'm not giving up yet vultures...lol.
