Cant Pop Seat - Wrist Twisters
 4Likes
  • 1 Post By KarlJay
  • 3 Post By ViralVendetta
post #1 of 13 Old 05-11-2018, 04:40 PM Thread Starter
ViralVendetta's Avatar
Cant Pop Seat
Hey guys, went out to try and get my seat off to look at my unertail and get ready for exhaust mod and when I turn the key nothing happens. It has always worked before, is there a trick to it? The key has some resistance but not much.
ViralVendetta is offline
post #2 of 13 Old 05-11-2018, 05:57 PM
Try gently pushing down on the back (passenger) part of the seat. Sometimes that works for me.
garyb900 is offline
post #3 of 13 Old 05-11-2018, 06:25 PM Thread Starter
Ok thx, guess it needs a little 3in1 oil
post #4 of 13 Old 05-11-2018, 08:21 PM
Not only push down, but push side to side/front/back... It's a hook/latch and can hang if friction is wrong.
Once you get it off, there's adjustments for position and height.
ViralVendetta likes this.
post #5 of 13 Old 05-12-2018, 01:51 PM Thread Starter
Dangit it wont pop up. Ok guys it may be broke or something. Whats the best way to get it off without breaking anything? I have to fix this its killing me, cant stand for something to be broke.
post #6 of 13 Old 05-12-2018, 02:48 PM
This might help. Looks like it's happened before.
https://www.wristtwisters.com/forums/...ad.php?t=28764
post #7 of 13 Old 05-12-2018, 05:30 PM Thread Starter
Seat Lock broken. Help help - Wrist Twisters
Woohoo, thanks IB that should work.
post #8 of 13 Old 05-12-2018, 06:34 PM
The bar that keeps the seat in place is held in a slit and is spring loaded so if it catches, it won't open all the way.
I'd turn the key then try to move the seat down and forward. One thing you might try is some WD-40 with a straw on the tip. Wedge the straw down in there and spray it around.
Maybe spray some into the key hole.
The seat tends to move a good bit, moving it around once the key is turned is about all you can do.
After that, maybe cut a hole in the bottom because you can always epoxy it back up.
post #9 of 13 Old 05-12-2018, 06:58 PM Thread Starter
Ok guys I got it. Thanks IB and Karl Here is a quick video to help others out in the future. Hope it helps the forum.
post #10 of 13 Old 05-12-2018, 08:03 PM
Good video.
post #11 of 13 Old 05-12-2018, 08:11 PM
So the key lobe thing fell off or broke?
How did that happen? Some clip fell off?
post #12 of 13 Old 05-12-2018, 09:19 PM Thread Starter
Fell off, I assume it had some kind of retention ring on it.
post #13 of 13 Old 05-12-2018, 09:19 PM Thread Starter
Good video.
Thx IB
