Can't get my rear wheel back on - Wrist Twisters
post #1 of 39 Old 03-28-2014, 05:51 PM Thread Starter
I've been battling this thing for half a day now, I can't get the rear wheel back on after I swapped the tire out. I'm running into a problem lining up the side collars. There is simply not enough space to align both and slide the tire into place where I can get the axel rod through. I need about a quarter inch of space more so I can set both the collars and push the tire forward/up, but I can't find a quarter inch of space anywhere. Any Ideas? Because I am fresh out.
I have the chain tension all the way forward, and putting the chain on doesn't a difference.
fritzwilliam is offline
post #2 of 39 Old 03-28-2014, 06:01 PM
Pierre-Marc
by the looks of your second picture I'd say you've got a damper rubber out of place and it's not fully seated into the wheel.
mx463 is offline
post #3 of 39 Old 03-28-2014, 06:03 PM
Are you sure you don't have the collared spacer backwards? Brake caliper mount is sitting in the groove properly?
post #4 of 39 Old 03-28-2014, 06:09 PM Thread Starter
I thought that too, but even if I take the dampeners out all together the driven flange still doesn't move all that much, not enough for me to work with anyway. It's been a while since I've had the rear wheel off this bike, is the flange being like that, even with the rubbers set properly, not normal?
post #5 of 39 Old 03-28-2014, 06:10 PM Thread Starter
Collared spacer is facing inwards, and is aligned with the indent.
post #6 of 39 Old 03-28-2014, 06:11 PM
Can you post a picture of what you've got?
post #7 of 39 Old 03-28-2014, 06:12 PM
Pierre-Marc
shouldn't be a gap between flange and wheel
mx463 is offline
post #8 of 39 Old 03-28-2014, 06:12 PM Thread Starter
Of the spacer/side collar?
post #9 of 39 Old 03-28-2014, 06:19 PM
Post pics of both sides.
post #10 of 39 Old 03-28-2014, 06:27 PM
The driven flange definitely looks screwy in that pic, but it could have just gotten skewed when you were messing with it. Try moving the chain adjusters all the way in (wheel as far forward as possible). It makes getting everything aligned and the axle in much easier.
Edit: oops I see you had the adjusters all the way forward.
post #11 of 39 Old 03-28-2014, 06:37 PM Thread Starter
Seems to be leaning towards to driven flange then, from what others are stating. I'm through with it tonight but will be sure to post a more detailed pic of the driven flange both open/closed tomorrow. Even with the dampeners out the gap stays relatively the same. The bearing looks fine and spins freely, and I don't see anything that could be obstructing the path of the driven flange, guess I'll have to go back over it.
post #12 of 39 Old 03-28-2014, 06:45 PM
From what I see, you have the spacers on the wrong sides. Here's a picture of a rear axle with the spacers.
post #13 of 39 Old 03-28-2014, 06:46 PM
There's an o-ring in a slot on the center of the wheel that the driven flange slips over. Maybe that came out of the groove and rolled and is binding it up.
post #14 of 39 Old 03-28-2014, 06:48 PM
Attachment 54481
Actually I think that pic is wrong
post #15 of 39 Old 03-28-2014, 06:52 PM
You're just looking at it upside down. Are you in Australia?
post #16 of 39 Old 03-28-2014, 06:54 PM
I hit CTRL-ALT-DOWN ARROW before I looked.
post #17 of 39 Old 03-28-2014, 06:57 PM
Huh? You must be super old. You still use a computer? Keyboard? :P
post #18 of 39 Old 03-28-2014, 07:00 PM
Here's my set-up
post #19 of 39 Old 03-28-2014, 07:11 PM
Here's my set-up
Ok, now I know that I'm old. I remember that set up.
post #20 of 39 Old 03-28-2014, 08:42 PM
Batman
velodesign's Avatar
Is that the high capacity 5.25 reader below? Oh flippydisc!
velodesign is offline
post #21 of 39 Old 03-29-2014, 05:30 AM
Honda919Rider #1
Here's my set-up
Crap, you've got me beat....
Steve is offline
post #22 of 39 Old 03-29-2014, 06:45 AM
Hey fritz, get it fixed up?
post #23 of 39 Old 03-29-2014, 06:49 AM
This made me go look at my bike. They have the spacers reversed. Either that is wrong or I've been running them backwards for years.
post #24 of 39 Old 03-29-2014, 06:58 AM Thread Starter
I went out and took a look again this morning, and I'm almost certain that my bearing is sticking out just enough to make the driven flange unable to fully seal with the hub. Can anyone verify that this looks messed up? Any ideas how to lower it back into the hub?
This is how far the flange will go against the hub without the dampeners in.
As for the spacers, this is what it has in the manual I'm reading from, the collard spacer goes on the sprocket side.
post #25 of 39 Old 03-29-2014, 07:09 AM
That beraring is way out! It should be flush against race lip/edge. You have a few options, depending on the tools and hammers you have ..... but it should reseat fairly easily since it is 75% in the race already helping to keep it straight.
- you can use a large socket to sit on the outer race and drive it back into its seat with a hammer.
- Drive it back in with a rubber dead blow hammer.
- Use a chunk of 2x4 over top of the bearing and drive it in with a hammer.
post #26 of 39 Old 03-29-2014, 07:10 AM
There is something wrong with that bearing from what I see. Are you able to move the bearing? I think the manual is wrong about the spacers. My bike is together and the uncollared spacer is on the sprocket side. Maybe someone else will confirm? Marylandmike?
post #27 of 39 Old 03-29-2014, 07:14 AM
Check the bearing and make sure its still servicable first. It should roll smooth and not knotchy/rough
post #28 of 39 Old 03-29-2014, 07:23 AM Thread Starter
Bearing spins freely, am going to give it a whack or two and see if I can get it to go back in.
post #29 of 39 Old 03-29-2014, 08:59 AM Thread Starter
Managed to get it back in with a hammer and 2x4. Thanks Helimech and everyone else as well who contributed. Tire is back on now, and I can move on to the greater problem plaguing everyone's mind that is which spacer goes on which side.
post #30 of 39 Old 03-29-2014, 09:07 AM
Just went out and looked, flanged collar is on the left (drive) side and straight collar is on the right (brake) side
post #31 of 39 Old 03-29-2014, 09:51 AM
Mine is like the manual, that's why I posted that I thought your pic was wrong. Check your VIN, maybe your bike was assembled in Australia or maybe you have the wheel on backwards.
post #32 of 39 Old 03-29-2014, 09:51 AM
ariannasdaddy's Avatar
Can someone confirm the spacers? Mine are the same as rickards and I know for a fact that it was line that when I bought the bike over three years ago.
Arte et Marte
ariannasdaddy is offline
post #33 of 39 Old 03-29-2014, 10:06 AM
I just checked my bike again. I have the wheel on backwards. My sprocket is on the right side and brake on the left. :P I guess the spacers will work either way.
post #34 of 39 Old 03-29-2014, 10:22 AM
"CERTIFIABLE"
Ken Phenix's Avatar
Me too. But I think the book is right.
I have had the spacer get caught on the left adjuster a time or two when installing the wheel. It makes sense now that the flanged spacer should go on the sprocket side to ride against the slotted adjuster.
Ken Phenix is offline
post #35 of 39 Old 03-29-2014, 10:38 AM
I am in the middle of chain maintenance and it won't be hard to try it the other way and see how it looks. I'm more concerned about the sprocket alignment being off.
Arte et Marte
post #36 of 39 Old 03-29-2014, 11:35 AM
I don't have a proper calliper but;
Spacing when done as the manual states.
And spacing when done the wrong way.
Either way, the alignment will be fine. I would like to say that the brake side looks more correct as the manual suggests.
Arte et Marte
post #37 of 39 Old 03-29-2014, 11:36 AM
It should look like this:
post #38 of 39 Old 03-29-2014, 12:23 PM
Yeah, only without so much dirt and road grunge everywhere...
K1w1Boy is online now
post #39 of 39 Old 03-29-2014, 01:21 PM
Oh no. I'm in trouble. Mine looks nothing like that! I'm gonna rip my whole bike apart to make sure I get it right.
