can am spider horn - Wrist Twisters
 1Likes
  • 1 Post By Mark919
post #1 of 4 Old 03-15-2018, 06:52 AM Thread Starter
mebikes
can am spider horn
Can I replace factory 919 horn with can am horn without any electrical mods?
MEbikesagain is offline
post #2 of 4 Old 03-15-2018, 09:03 PM
Canadian Blue
Mark919's Avatar
I'm not familiar specifically with a 'can am horn'. If there is a specific model for the horn I'd suggest you find some specifics from the manufacturer and find out it's ampere requirements.
The OEM honda horn draws something around 4 amps, which is likely what the wiring and switch are designed for - without a relay.
Most loud aftermarket horns draw well more than 4 amps and they suggest using a relay so they meet the high dB rating and do it without damaging the vehicle switch & wiring.
I've changed to louder horns in all the bikes I've owned and always added a relay. Typically a relay is about $5 and you can find a lot of good references on how to configure it.
But I also know folks who have replaced the oem horn with a louder automotive horn and used no relay and had no apparent problem.
My 2 cents,
Good luck,
Mark
KarlJay likes this.
Mark919 is offline
post #3 of 4 Old 03-16-2018, 07:39 AM Thread Starter
mebikes
Thank you... You gave me a starting point.
post #4 of 4 Old 03-20-2018, 10:50 AM
I replaced mine with a Stebel. Well worth it, very loud:
