Broken brake fluid window - Wrist Twisters
post #1 of 19 Old 10-10-2014, 10:18 AM Thread Starter
dazed and confused
EscapedLabRat's Avatar
So yesterday I got a call from a friend saying that she was stranded; the bike wouldn't start and was leaking fluids. Fearing a blown gasket and a seized engine I raced over... to find that it was a dead battery and a broken brake fluid window.
Anyways, the bike is an '06 gx250, and the part that broke was the little window in the brake fluid reservoir on the handlebars. Does anybody have an idea for a patch that would hold up until I'm able to put a new master cylinder assembly on for her? Is there any type of putty (JB weld type stuff) that is brake fluid resistant?
EDIT: If anybody knows of a way to replace just the window that would be great too; I dind't mention it since bikebandit's diagram shows it being a single unit.
EscapedLabRat is offline
post #2 of 19 Old 10-10-2014, 11:15 AM
A dime (or other coin) and some epoxy?
post #3 of 19 Old 10-10-2014, 11:55 AM Thread Starter
dazed and confused
Hmm, that seems like it'd work. A quick googling has come up with numerous instances of many kinds of epoxy deteriorating in brake fluid, including a few iffy reports on JB. I need to find something that'll last for a while since the friend currently doesn't have the cash to replace the master (broke grad students here). Does anybody have any first-hand experience with epoxy and brake fluid?
post #4 of 19 Old 10-10-2014, 12:17 PM
We are going to need some pictures of your friend to enable us to help you better.
post #5 of 19 Old 10-10-2014, 12:24 PM
Yo no sť nada
spyke1019's Avatar
spyke1019 is offline
post #6 of 19 Old 10-10-2014, 01:34 PM
While JB Weld may react to brake fluid in the long run, it will serve as a temporary patch adhesive until a replacement master cylinder is installed.
On the other hand Marine Tex epoxy has served me quite well when patching fuel tanks, and I once built a "temporary" rear master cylinder from several pieces bonded together with it, and instead of having to make another from billet it proved to work so well it is still in service some 10 years later.
Impertinent question: how the hell did it get broken?!
post #7 of 19 Old 10-10-2014, 01:36 PM Thread Starter
dazed and confused
Jeeze, leave it to internet lechers to jump at the mention of a college girl.
post #8 of 19 Old 10-10-2014, 01:43 PM Thread Starter
dazed and confused
Looks like I'll be huntin down some marine tex.
As for how it broke... I've got nothin. It's obvously rotten through, but it was still somehow punched inwards. She says that she has no idea either, so either someone else messed with it, or she accidentally stabbed it when she was freaking out about it not starting.
post #9 of 19 Old 10-10-2014, 03:17 PM
Oh its a college girl! You're gonna need a jeep and some ice cubes.
post #10 of 19 Old 10-10-2014, 04:35 PM Thread Starter
dazed and confused
Well, vet student. Not a "like, OMG" sorority girl (aka the jeep type).
Anyways, upon cross-examination, she admitted that she didn't know what the window was... so she pushed on it.
post #11 of 19 Old 10-10-2014, 05:21 PM
A vet student that rides is much better than any old sorority chick. Hope you can help her get her bike back on the road.
post #12 of 19 Old 10-10-2014, 06:58 PM
gn83tm's Avatar
The guys on the Nighthawk forum use a watch crystal to replace the sight glass on a master cylinder. Might look into that.
gn83tm is offline
post #13 of 19 Old 10-11-2014, 05:26 PM
Ah, that's a good idea. A cheap woman's watch is probably about the right size, too.
Back to the epoxy question, I remembered buying some epoxy that was for Marine use; it could be mixed and would harden under water, and was water insoluble.
Since brake fluid is water soluble as well, I bet that Marine grade epoxy would work.
And it set up REALLY hard, I used it to fix a cap on a water jug.
post #14 of 19 Old 10-11-2014, 05:33 PM
What brand of watch does a cheap woman wear? I asked my wife but she said she just uses her phone.
post #15 of 19 Old 10-11-2014, 06:32 PM
gn83tm's Avatar
Here's a link to a thread discussing it: Login
Sounds like Esslinger.com and regular old RTV get the job done.
gn83tm is offline
post #16 of 19 Old 10-11-2014, 07:27 PM
You know, I 'just' about googled Cheap Woman images, but thought better...
post #17 of 19 Old 10-11-2014, 07:43 PM
It will be fine as long as your safe search filter is on
post #18 of 19 Old 10-11-2014, 08:29 PM Thread Starter
dazed and confused
Thanks! I'd seen the watch glass idea a couple different places, but I couldn't find any mention of where it was sourced from. Sadly the link you posted doesn't work for me since I don't have a nighthawk forum login.
Do it and let us know what you find. On second thought, I'm not sure I'd want to know...
post #19 of 19 Old 10-11-2014, 11:10 PM
Measure in MM the window size, call a watch repair shop and tell them you'd like a mineral crystal replacement for that size. Don't get up-sold for a sapphire lol. Seiko Hardlex should be available in the smaller sizes.
