brakeline bolt size - Wrist Twisters
post #1 of 8 Old 04-13-2018, 07:58 AM Thread Starter
brakeline bolt size
Can any1 tell me what thickness are hoses are and what is the master cylinder bolt size 10 x 1.00 or 10 x 1.25 ???
Niner101 is offline
post #2 of 8 Old 04-13-2018, 12:28 PM
All the banjo bolts on the 919 are M101.25. They are also 22mm long. Are you after the stock brake hose diameter?
post #3 of 8 Old 04-13-2018, 01:44 PM Thread Starter
YES
YES STOCK NUMBER OR THE SIZE FOR STEEL BRAIDED ONES
Niner101 is offline
post #4 of 8 Old 04-13-2018, 01:53 PM
I don't know the diameter of the hoses. Can I ask why you want the diameter?
post #5 of 8 Old 04-13-2018, 02:26 PM Thread Starter
LOCAL
I WAS GONNA SEE IF I COULD GET SOME MADE LOCAL JUST WANTED TO MAKE SURE I HAD MY DUCKS IN A ROW
Niner101 is offline
post #6 of 8 Old 04-14-2018, 12:18 AM
Don't know the stock diameter (tossed mine years ago), but the braided lines are invariably dash 3, indicating the inside diameter of the hose is 3/16". The O. D. Is roughly 5/16" with the usual plastic sleeve covering it.
If you can't find a local supplier I recommend calling G&J Aircraft and surplus. For more info go here:
http://https://www.wristtwisters.com/...nes-10307.html
post #7 of 8 Old 04-14-2018, 10:02 AM
The link doesn't seem to be working. Trying again:
https://www.wristtwisters.com/forums/...nes-10307.html
That's better.
post #8 of 8 Old 04-15-2018, 08:15 PM Thread Starter
I will def. Call them if the 1 hosemaker here doesn't have them or if their way expensive....
Niner101 is offline
