Brake feel - Wrist Twisters
post #1 of 11 Old 06-05-2014, 01:38 PM Thread Starter
CKutz_GO's Avatar
Brake feel
Real simple question guys, as i plain just don't remember or no the difference between stainless line and regular (last bike had stainless).
When i first start out on the bike my front brake is weak. after a couple pulls it firms up.. it might loosen up if i don't use it for awhile.. haven't really thought about it. Is this air/moisture in the line that gets compressed and then i don't notice it? or is this how rubber lines perform? or is this how breaks always are haha
I believe SS lines are for preventing expansion of the line (causing inconsistent feel) under hard breaking.. but i thought i'd check as i'm trying to put off doing any work to the bike till i have to! the last bike was being rebuilt till the end of june last year and this year i'm all about the "get on and go" niner and getting in as much as I can. I just rolled over 10k miles so it's probably due for a break bleed anyways but the fluid doesn't look atrocious yet. 2500 miles in 2.5 months.
CKutz_GO is offline
post #2 of 11 Old 06-05-2014, 02:16 PM
It certainly sounds like air in the line to me. Pump it a few times and the bubbles disperse. Try putting a ziptie around the throttle and brake lever overnight. It may let the air bubbles rise into the mastercylinder. I don't see moisture compressing much. I won't comment on the action of SS lines, but they feel better to me. Hopefully they have the same effect on the CBR250 as they did the 919. I swear the CBR250 gives 0 brake feedback.
post #3 of 11 Old 06-05-2014, 02:41 PM Thread Starter
CKutz_GO's Avatar
Good point on the moisture haha
CKutz_GO is offline
post #4 of 11 Old 06-05-2014, 02:44 PM
You might want to replace the brake fluid if you haven't already, when was it changed last? I wouldn't let it go more than two seasons.
post #5 of 11 Old 06-05-2014, 02:49 PM
At my last tyre change, I bumped the front brake lever and shot the pistons a fair way out of the calipers - not excessive, just more than the usual travel - and had to lever them back in to make way for the disk as I replaced the wheel.
After the reassembly, I found a lot more early bite in my brakes than was there previously, so the extension/ retraction process must have disturbed some lurking bubbles, and finally chased them away. You might want to give it a try.
K1w1Boy is offline
post #6 of 11 Old 06-05-2014, 03:01 PM
Old fluid, old lines and a little air in the system can contribute to a lever that requires being pumped up initially, but many times there is a slow leak somewhere that is the real culprit.
Spend the time to replace the fluid and then bleed the lines properly. Once the lever is firm it should remain that way period. If it gets squishy an hour, a day or a week later you have a leak somewhere.
post #7 of 11 Old 06-05-2014, 03:09 PM Thread Starter
CKutz_GO's Avatar
Alright thanks!
CKutz_GO is offline
post #8 of 11 Old 06-05-2014, 03:10 PM
If you have any problems along the way PM me and I will get you sorted.
post #9 of 11 Old 06-05-2014, 03:14 PM Thread Starter
CKutz_GO's Avatar
Yup, not really sure when it was last changed. But sounds like its due for it. Was hoping it was normal for the first couple squeezes to be squishy but sounds like its getting added to the stop-riding-and-maintain list haha
Thanks guys.
CKutz_GO is offline
post #10 of 11 Old 06-05-2014, 03:32 PM
Use the Valvoline DOT3/4 stuff you can get from any auto parts store. It's about $2.99 a bottle and works excellent even for track use. Saves you a bundle over motorcycle specific brake fluids.
post #11 of 11 Old 06-05-2014, 04:36 PM
That's what I use...being a cheap bastard and all
