Bought T Rex Sliders... How should I install these to the frame? - Wrist Twisters
 2Likes
  • 1 Post By redline919
post #1 of 5 Old 08-28-2016, 02:33 PM Thread Starter
Per advice of the forum, I plan on installing to the frame and ordered to 'long' sliders, which have arrived.
What's the best way to mount to the frame? put a threaded bolt through the frame? Tap the holes in the frame and simply screw in a bolt? what size / strength bolts should I be looking for?
Many thanks. This is all new to me and any advice is appreciated.
williepedia is offline
post #2 of 5 Old 08-28-2016, 03:35 PM
redline919's Avatar
The best way is to have a continuous threaded rod through the frame. 10mm in diameter.
williepedia likes this.
redline919 is offline
post #3 of 5 Old 08-28-2016, 04:17 PM Thread Starter
Dumb question: how does the 10mm threaded rod connect to the sliders? Put it through the slider with a nut/washer on each side?
post #4 of 5 Old 08-28-2016, 04:21 PM
redline919's Avatar
That is correct.
post #5 of 5 Old 10-07-2016, 03:35 PM
make sure you use washers just in case the rubber/plastic/delrim (sp?) on the actual frame slider puck doesn't have the built in washers inside them.
never hurts to add an extra washer on each side....just to be sure you don't squeeze/pinch the rubber of the frame slider too much.
VintageHunter
"always looking for that next find".
1984 Yamaha Seca 400
1984 Honda CB125
1987 Yamaha RZ350
Various Yamaha YSR50, YSR200, YSR80
1986 Honda 500 Interceptor
1998 Yamaha R1 (first original R1)
2006 Kawasaki Ninja 250
1997 Kawasaki ZX7
1989 Honda GT650 Hawk
1989 Honda CB-1
2001 Honda CBR F4i
VintageHunter is offline
