Bosch oil filter change? - Wrist Twisters
post #1 of 34 Old 04-16-2015, 07:40 PM Thread Starter
So I always thought guys were crazy when they couldn't get the Bosch 3323 to fit, but tonight I went to do a change and the new one just wouldn't go on. I tried reinstalling the old one, and it slipped right on. I put them side by side and noticed the new one was flat in the middle, maybe even a little convex, where the old one was concave allowing it to slide over the threads.
I gave the new one a few gentle taps and then it fit fine but it has me curious...
Has anyone else seen this? Did Bosch change their design or did this one just not get finished correctly?
post #2 of 34 Old 04-16-2015, 07:47 PM
Total Awards: 17
Never used bosh on the 9er. Mobil1 is a little more but its supposed to be of the better quality
zaq123 is offline
post #3 of 34 Old 04-16-2015, 08:13 PM
I thought both were champion filters? Or maybe I'm thinking Bosch and k&n are by Champion.
Never had a problem fitting a 3323 before... now I gotta check the parts store and see if it's in or out.
post #4 of 34 Old 04-16-2015, 08:17 PM Thread Starter
I've never had an issue either... I tried for probably 20 min to get the new one on before I realized it was off...
post #5 of 34 Old 04-16-2015, 08:18 PM
Never used anything but the OEM filters.
garyb900 is offline
post #6 of 34 Old 04-16-2015, 08:29 PM
NWTB Non Stinky 919
jeffie7's Avatar
Have a 3323 on mine as well, I'll have to check next time I change it.
jeffie7 is offline
post #7 of 34 Old 04-16-2015, 10:50 PM
Had the issue myself recently. Thought maybe my headers got tweaked or something. Nice to know it was actually the filter! Getting it off will be a bitch though.
post #8 of 34 Old 04-16-2015, 11:09 PM
So the outward one is the one that doesn't fit right? I've never seen the filter like that.
post #9 of 34 Old 04-17-2015, 12:19 AM
Dewbie
bacis's Avatar
I had to toss the 3323 I bought; no way it was going on. I had already oiled it so I just ate it rather than trying an online return. Fortunately I hadn't yet tossed the one I took off.
bacis is offline
post #10 of 34 Old 04-17-2015, 03:23 AM
Total Awards: 17
Bosch has been made by Purolator for a quit some time now for US market. M1 is still Champion filter.
zaq123 is offline
post #11 of 34 Old 04-17-2015, 03:32 AM
crimedog's Avatar
I just put one on and it went on fine although a little tight as expected. I did purchase it in the fall, but it has the new box like yours.
08 DR-Z400SM
WFOATT
crimedog is offline
post #12 of 34 Old 04-17-2015, 05:25 AM Thread Starter
The last one I put on was also in the new box and it went on fine
post #13 of 34 Old 04-17-2015, 05:26 AM Thread Starter
Correct... I gave it a few solid taps with the rounded head of my ratchet to shape it a little and it went on fine then... I'm still deciding if I feel comfortable with that or not...lol
post #14 of 34 Old 04-17-2015, 05:38 AM
carotman's Avatar
I tried the 3300 without problem. The 3323 is longer so it might interfere a bit with the header.
carotman is offline
post #15 of 34 Old 04-17-2015, 08:13 AM
CKutz_GO's Avatar
i definitely had to be a bit forceful getting mine on. i just put it on a few weeks ago.
so are we just paying for a name on the Bosch one? better off going with the mobil?
CKutz_GO is offline
post #16 of 34 Old 04-17-2015, 12:05 PM
Didn't know that. Purolator makes great filters too but I'm hesitant with forcing one on. Looks like shelling double for the Mobil from now on.
For people wondering why we don't just buy Honda filters, these are readily available at most auto shops and there are many online comparisons showing these having superior media.
post #17 of 34 Old 04-17-2015, 01:13 PM
NWTB Non Stinky 919
jeffie7's Avatar
Better filter for less money. Unless you are and OEM guy that thinks it's better than all else. Of course over the years OEM filters change. You just don't know it.
jeffie7 is offline
post #18 of 34 Old 04-19-2015, 11:01 AM
captainchadl's Avatar
Oil Filter Comparison Study - GM Truck Central
I use K&N, it makes my oil changes faster because of the nut on the filter. According to this test K&N is supposed to be better at filtering than a Purolator, which is what I used to use on my shadow every oil change.
captainchadl is offline
post #19 of 34 Old 04-19-2015, 01:25 PM Thread Starter
Originally Posted by captainchadl View Post
Oil Filter Comparison Study - GM Truck Central I use K&N, it makes my oil changes faster because of the nut on the filter. According to this test K&N is supposed to be better at filtering than a Purolator, which is what I used to use on my shadow every oil change.
Why would the nut make it any faster? If you need to use the nut you're putting it on too tight
post #20 of 34 Old 04-19-2015, 01:40 PM
It's a lot easier to use a combination wrench to take off the oldfilter than it is to use a filter wrench. You don't use a wrench to put on an oil filter, hand tight is all you need, that part isn't rocket science.
post #21 of 34 Old 04-19-2015, 01:45 PM Thread Starter
I've never needed a wrench to take one off either... At least not one that I've put on
post #22 of 34 Old 04-19-2015, 01:46 PM
Is the oil hot when you change your oil?
post #23 of 34 Old 04-19-2015, 02:31 PM
Why would you change the oil when it's hot?
post #24 of 34 Old 04-19-2015, 02:36 PM
I run the engine for about 5 mins before the oil change. I always put the filter on hand tight but most always need an oil filter wrench to get it loose the next time.
post #25 of 34 Old 04-19-2015, 02:54 PM
You should change the oil when it is hot, it will be thinner and drain better.
post #26 of 34 Old 04-19-2015, 02:55 PM
Right, because as metal gets hot it expands.
post #27 of 34 Old 04-19-2015, 02:57 PM
I usually just put a candle under the oil pan..
post #28 of 34 Old 04-19-2015, 03:10 PM Thread Starter
Yep, I usually drop the oil right when I get home from work (35 mile drive)
post #29 of 34 Old 04-19-2015, 03:31 PM
"CERTIFIABLE"
Ken Phenix's Avatar
I understood the Mobil 1 and NAPA Gold filters were made by WIX. I prefer WIX unless I go to the dealer to ogle the bikes.
This might be helpful here:
Oil filter options for the 919
Oil Filter Dimensions
20 x 1.5mm threads
14 psi bypass valve
Anti-drainback valve
2.3" O.D. gasket
2.5" to 3.5" long
Motorcycle Filters
OEM - Kawasaki 16097-0004
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
HiFlo HF303 (HF303C for chrome version)
Honda 15410-MCJ-000
K&N KN-204 (Made by HiFlo, 75mm long, Metric nut on end for easy removal)
K&N KN-303 (Made by HiFlo, 85mm long, Metric nut on end for easy removal, KN-303C for chrome version)
NAPA Gold 1358
Purolator ML16817 (Imported from China, not made by Purolator)
STP SMO 17
WIX 51358
Automobile Filters (~2.5" long)
AC Delco PF1237
Baldwin B1400
Bosch 3300
Firestone TF2876
Hastings LF113
K&N PS-1008
K&N HP-1008 (same as Mobil1 with nut welded on)
K&N SS-1008 ($200+, reusable stainless steel mesh filter)
Mobil 1 M1-108
NAPA Gold 1365
Purolator L14612
Purolator Pure One PL14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters (~3.25" long)
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Bosch 3323
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
K&N PS-1010
K&N HP-1010 (same as Mobil1 with nut welded on)
K&N SS-1010 ($200+, reusable stainless steel mesh filter)
Mighty M4612
Millard ML-3593
Mobil 1 M1-110
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Purolator Pure One PL14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867
Valvoline VO50
WalMart SuperTech ST7317
Warner PH2867
Wix 51356
Ken Phenix is offline
post #30 of 34 Old 04-19-2015, 05:17 PM
I generally do my oil changes while needing to do other things. I have no problems with draining the oil while cold, which I would rather do so all the possible oil to drain, drains back into the pan before draining out.
Here is a good cross reference list that works really well. Lists cross references for many different brand/models of motorcycles.
Motorcycle Oil Filter Cross Reference
post #31 of 34 Old 04-19-2015, 06:48 PM
i have always used the HF-204 from hiflo filtro on my 9er, OEM quality, great price, no fitment issues.
I do typically change both oil n filter every 3-4k miles if im not using the bike much... or if its gonna be a lot of riding during the summer ill change the filter after 2 3-4k interval oil changes if its within say 6-8 months.
post #32 of 34 Old 04-20-2015, 01:35 PM
redline919's Avatar
No issues here with the 3323. I'm using it on the 9er and my brothers fz8
redline919 is offline
post #33 of 34 Old 04-20-2015, 02:28 PM
Cloroxbleach4's Avatar
I use the Mobil 1 M1-110. It's the 3.25" Perfectly fits a gallon of oil.
Cloroxbleach4 is offline
post #34 of 34 Old 04-20-2015, 03:17 PM
redline919's Avatar
Hmmm. I was thinking that one might fit the bike. That's the one I use on my Crv . Gotta love Honda
