Blinker Problem... Won't turn on unless opposite is used first. - Wrist Twisters
post #1 of 7 Old 09-27-2013, 04:25 PM Thread Starter
Man and Machine
Callinmeupward's Avatar
I was checking around on the 919.. Headlights check, brake lights check, taillight check, left turn signal good , right turn signal worked for 3 seconds then nothing. I try turning on the right signal from center position (off) and have nothing front and back. What's going on here. It worked fine recently and I havent done anything to the bike to have hit a wire. Stock wiring to eBay blinkers and fender eliminator tail light.
Callinmeupward is offline
post #2 of 7 Old 09-27-2013, 04:53 PM
Have you ridden in the rain lately? The connections in the handlebar housing probably need to be cleaned. It's been happening to me lately on the left signal.
2012 Yamaha Super Tenere
2001 Honda Blackbird
post #3 of 7 Old 09-27-2013, 05:45 PM
Happened to me before, cleaned the housing like Sckill said. Just flooded it with WD40 while working the switches. Should've taken it apart and gave it a good cleaning but if you need it on the pinch..
post #4 of 7 Old 09-27-2013, 06:45 PM Thread Starter
Man and Machine
I will go try this! Thanks.
post #5 of 7 Old 09-27-2013, 06:59 PM Thread Starter
Man and Machine
Tried it.. Same thing. Hmm.
post #6 of 7 Old 09-28-2013, 01:31 PM Thread Starter
Man and Machine
Looks like wd40 did the trick overnight: ) blinker works like normal.
post #7 of 7 Old 09-28-2013, 04:12 PM
Cool!
