Bike won't start - Wrist Twisters
post #1 of 11 Old 09-04-2012, 07:01 AM Thread Starter
Bike won't start
Well, I have a problem with my DRZ
(i've been over to thumpertalk, and no help on this one so someone might have an idea here) I'll shorten the story
Went for a ride the other day, bike stopped running and wouldn't start (I've been having a problem with rust in the tank clogged the PJ) Took the carb out, cleaned it and the bike struggled to start but it did start, Rode it up to the nearest road to go home and it died again but started so I headed right for home.
On my way home It felt like a lost of power (Not huge lost of power, but some) when I pulled it the driveway the bike just shut off (It got me home though) Now it won't start, So here's what I've checked so far
Carb is cleaned again
new spark plug, it has very strong spark
the timing is right (Checked from TDC and looking at the cams)
Cam chain tensioner is manual, and doesn't appear to have backed off
Ignition timing is non adjustable on these bikes
Valves are in spec except for one exhaust is just alittle tight.
Checked over the wiring, and the dummy switches (kickstand and clutch switches have been removed on this this)
I drained the oil, looks like oil and doesn't smell like gas or coolant.
The starter will run, and I can feel the piston moving, It wants to start but it won't kick. The plug is wet after abit, so it's getting fuel and has spark so does this leave me with lack of compression?
I just found it weird since to rode home good then just died, wouldn't a lack of compression been really noticeable on the ride home that day?
Any help would be great, I just didn't want to start tearing the top end apart if I didn't have to, although it looks like I will be.
03 DRZ 400
05 VFR 800A
05 GSXR 1000
04 Honda 919
00 Honda Shadow ACE
Epicsoldier is offline
post #2 of 11 Old 09-04-2012, 07:32 AM
Hmm. It has air, fuel and spark... do a compression test? Thats about all thats left to do... good luck, Ben!
post #3 of 11 Old 09-04-2012, 07:37 AM
Battery?
post #4 of 11 Old 09-04-2012, 09:17 AM Thread Starter
Yeah I figured that would come up, wish I had a compression tester. Might have to take her to the local shop for a test.
Thanks though!
And the battery seems good, it has no problem cranking it over and over and over.
03 DRZ 400
05 VFR 800A
05 GSXR 1000
04 Honda 919
00 Honda Shadow ACE
post #5 of 11 Old 09-04-2012, 09:26 AM
so your carb is getting gas? i have seen some issues with the vacuum petcock... turn it to prime.
but if you are getting gas, and spark then hmm... never heard of such weird things with a drz.
post #6 of 11 Old 09-04-2012, 09:27 AM
My suggestion is the same as above, check the battery and associated connection points. You'd be surprised that a battery has enough juice to crank the starter, but not have enough to get the bike to fire up. It sounds to me like either a bad battery or a loose battery connection/ground wire. Remember, KISS!
post #7 of 11 Old 09-04-2012, 09:40 AM
Have you removed the petcock and cleaned it out? If you're having rusting issues, I'd pull the tank and get that issue taken care of first.
post #8 of 11 Old 09-04-2012, 10:10 AM Thread Starter
Yep, The petcock is new (few months ago) and the screen has been cleaned out. The battery is also new as of last spring, but I will put it on charge just to take that out of the equation.
Mind you, the motor has about 17K miles on it and the valves are worn (as I'm adjusting them alot, I just wanted to try to make it till the winter) It has been drinking oil (When I bought the bike, the valves were tight and f*cked the valve seals so I'm assuming that is where the leak was) I had a leak down and compression test done in the spring and it all showed good except for a 5% leak at 100psi.
When I say drinking oil, it wouldn't burn/smoke all the time, only the odd time usually during deceleration and it would only last 15 seconds and stop for awhile. When I drained the oil yesterday, I have a magentic drain plug and there was a huge goop of what looked like grease on the plug (never seen that when I changed the oil before)
I heard before that carbon + oil and make is goop like grease? is that true? I'm almost wondering if the motor is carbon-ed up to the point where a valve is stuck open? I'm gonna clean the oil screen (DRZ's are dry sump) and maybe pull the side cases off to see if there is anything wrong in them. I'll throw the battery on charge and check out the connectors also.
03 DRZ 400
05 VFR 800A
05 GSXR 1000
04 Honda 919
00 Honda Shadow ACE
post #9 of 11 Old 09-22-2012, 07:02 PM
redline919's Avatar
My buddy had the same problem. It was the valves. It would be hard to believe 17k on a Drz without head work
redline919 is offline
post #10 of 11 Old 09-22-2012, 09:25 PM
Your problem is that you bought a DRZ. You have a compression problem like most of them develop after not terribly long, either rings or valves; one of my local shops does head and cylinder work for thumpers and you can watch their eyes light up when someone says they have a DRZ. Not knocking your bike, just pointing out that this is a known issue with the thing.
Most likely valves, based on your description. And it's going to do it again at about the same interval once you put it back together.
post #11 of 11 Old 09-22-2012, 11:10 PM
Now before you condemn you bike...I have a few ideas to try first. I have to say I don't know much about bikes so if I say something idiotic, well, that's why. Now, if it were a car id say to check fuel pressure, could be fuel filter or pump, check air filter (could be really clogged?), and finally if u have a catalytic converter, since its been smoking, it could be clogged.
84interceptor is offline
