bike lift "cradle" - Wrist Twisters
post #1 of 30 Old 09-20-2013, 04:20 PM Thread Starter
Gran Tirono
Asraiil's Avatar
bike lift "cradle"
Anyone ever had to make a cradle to lift a bike that doesn't have a lower frame (like my Monster)? a friend let me borrow his lift so I could change the fork seals, but after looking at it, I see I'd need to build some supports to get it stable without crushing the headers.
Another option would be to build a sling and use the hook and pulley I have on my garage ceiling (for my jeep hardtop), throw some ratchet straps on the bike frame and lift her that way. The hook is rated to 500lbs, and the duc only weighs 390 (stock), so I think it'd be easier to do that, but I'm wary of weird weight shifts once I pull the forks and front wheel off.
What say you guys, which one sounds like the better (as in less likely to screw my bike up) option?
Asraiil is offline
post #2 of 30 Old 09-20-2013, 05:05 PM
"CERTIFIABLE"
Ken Phenix's Avatar
From the attic, I lag screwed pieces of flatbar to the rafters so they protrude through the ceiling a bit. Then I connected cheap harbor freight cable hoists and made loops of heavy nylon strap to wrap around the bars. Works great. Cheap too.
I use 3 points but 4 would work even better.
Ken Phenix is offline
post #3 of 30 Old 09-20-2013, 05:30 PM Thread Starter
Gran Tirono
Asraiil's Avatar
Nice! Did you use anything like a rear stand to stabilize the back end?
I'm planning on lifting the whole bike, but it's good to see other options, in case I just decide I only want to worry about the front end...
Asraiil is offline
post #4 of 30 Old 09-20-2013, 05:48 PM
Nice! Looks like a wheelie trainer.
post #5 of 30 Old 09-20-2013, 06:29 PM
Wheelie trainer is easy, turn your tip sensor around to one side they tip it to just beyond the height you want to try out. So if you go to far the motor shuts down.
NZspokes is offline
post #6 of 30 Old 09-20-2013, 06:32 PM
"CERTIFIABLE"
Ken Phenix's Avatar
Right now I have one hoist for the back but I'm thinking about adding another.
I can easily set the bike on safety stands while tethered to the rafters for added stability.
post #7 of 30 Old 09-20-2013, 09:21 PM
Will fly for food.
filipinoaviator's Avatar
I prefer the 'overkill' method...
car lift and some 550 parachute cord
1965 PA-30 Twin Comanche
1985 Kawasaki GPZ900r
1999 Honda CBR1100XX
2005 Honda ST1300
2006 KLX250s
filipinoaviator is offline
post #8 of 30 Old 09-21-2013, 03:20 AM
We have a member in the the Philippines that used a ladder and ratchet straps. It was simple and effective but for life of me, can't remember his method. He posted a picture with his wheels and forks off is how I remember.
post #9 of 30 Old 09-21-2013, 08:11 AM
You're not thinking of my setup are you? Lol
...on my Droid.
post #10 of 30 Old 09-21-2013, 01:52 PM
No, are you talking about the steel bar across the center stand??
I forget his name but he has an ohlins shock and I believe it's an asphalt color 919. I want to say he used 2 ladders to lift the front of the bike.
post #11 of 30 Old 09-21-2013, 10:42 PM
I just used one ladder for the front, like an a-frame. Crossed the straps for stability. Have done it seven or eight times now without issue.
...on my Droid.
post #12 of 30 Old 09-22-2013, 06:51 PM
jclong74's Avatar
This is what I use
Pit Bull Motorcycle Stands & Accessories: Hybrid Headlift Stand
2006 919 (Sold)
2011 Cb1000r
jclong74 is offline
post #13 of 30 Old 09-22-2013, 08:36 PM
2 jack stands on the frame sides just behind the motor... And a floor jack under the exhaust... Bike in the air in 1 min...
post #14 of 30 Old 09-22-2013, 09:19 PM
Man and Machine
Callinmeupward's Avatar
Callinmeupward is offline
post #15 of 30 Old 09-22-2013, 09:51 PM
Jack stands under the rear, when needed. Ladder works great, is more stable than it seems it would be.
post #16 of 30 Old 09-23-2013, 08:35 AM
This is how the pros do it...
post #17 of 30 Old 09-23-2013, 10:58 AM
Good ideas, all of them... When I swapped the forks out, I used jackstands under the frame sliders. Worked like a charm....
robroten is offline
post #18 of 30 Old 09-23-2013, 12:10 PM
I've got a Gorilla ladder too. I like it!
post #19 of 30 Old 09-24-2013, 06:27 AM Thread Starter
Gran Tirono
Asraiil's Avatar
Thanks guys, lots of good ideas here. Since I have the hoist and hooks in the ceiling already I'm going to give that a shot. Maybe use the jackstands for some added stability in the rear.
Asraiil is offline
post #20 of 30 Old 09-24-2013, 01:54 PM
"CERTIFIABLE"
Ken Phenix's Avatar
Just make sure your "hook" is bolted horizontally through the rafter and not just screwed in from the ceiling. At my old place I threw a chain around a rafter.
post #21 of 30 Old 09-24-2013, 05:04 PM
This one has special attachments for the forks
post #22 of 30 Old 09-24-2013, 05:11 PM
post #23 of 30 Old 10-15-2013, 08:54 PM
Bwbkicks's Avatar
Originally Posted by jclong74 View Post
I'm looking into getting one of those. Have you run into any issues?
Bwbkicks is offline
post #24 of 30 Old 10-16-2013, 04:25 AM
crimedog's Avatar
My garage is unfinished inside, do you guys think I could just use ratcheting tie downs thrown over ceiling joists or would it be too much weight to ratchet up?
08 DR-Z400SM
WFOATT
crimedog is offline
post #25 of 30 Old 10-16-2013, 05:26 AM
Depends on the weight rating of the strap & the strudyness/design of the ratcheting mechanism.
Tie downs aren't mechanically designed to be used to lift something, u don't have a lot of mechanical advantage in most designs.
post #26 of 30 Old 10-16-2013, 05:57 AM
"CERTIFIABLE"
Ken Phenix's Avatar
You'll have no way to control the bike's decent. That's one reason why I use the cable hoists.
post #27 of 30 Old 10-16-2013, 06:02 AM
Haha! Never even thought about that part. Good call Ken!
Now I need to get a coffee before posting anymore.
post #28 of 30 Old 10-16-2013, 06:40 AM
crimedog's Avatar
Thanks for the help brain storming! I think I'll get one cable hoist and two tie downs. Once I have a project that requires getting the bike up at least.
08 DR-Z400SM
WFOATT
crimedog is offline
post #29 of 30 Old 10-16-2013, 07:03 AM
Originally Posted by Callinmeupward View Post
This one to me looks sketchy. Can't really talk since Clorox and I used the ladder method. One of the straps started loosening and we panicky hulked the bike upright.
post #30 of 30 Old 10-16-2013, 07:59 AM
Man and Machine
No way that was solid... Thick bar right underneath the frame neck then running across steel saw horses.... It wasnt going anywhere...
