battery help - Wrist Twisters
post #1 of 5 Old 03-06-2015, 09:12 AM Thread Starter
Garcia242's Avatar
battery help
My battery on my 2005 CBR600RR keeps dying and I'm trying to figure out why. It very well may be that the battery is just old but I have a sneaking suspicion that there is more to it than that. I'm not very electrical savvy so I could use a little help. How can I determine if it's just a bad battery or it is another component that need replacement?
my name is steve
i live in a box
my favorite color is clear
Garcia242 is offline
post #2 of 5 Old 03-06-2015, 09:15 AM
a load tester is the best way to test it, just about any place that sells batteries should have one... for a quick home test you can put a voltmeter on the battery and watch how much it drops when you key on (maybe a slight drop momentarily but not much) and then try to start and see how much it drops (a few volts isn't bad much more than that is a bad battery) How old is the battery and how frequently does the bike get ridden/ what problems have you been having specifically?
post #3 of 5 Old 03-06-2015, 10:11 AM Thread Starter
Garcia242's Avatar
I don't remember for sure but I think only two years old. Seems like I replace them too often. I think there is a power drain somewhere in the system killing the batteries prematurely. It's a race bike so it does sit idle for about two months in the winter.
post #4 of 5 Old 03-06-2015, 11:21 AM
CB700S is online now
post #5 of 5 Old 03-06-2015, 11:21 AM
do you leave it in the bike wired up over the winter? First thing I would do is remove the battery, charge it up, and leave it inside for the winter... if it's only a race bike, you could even do that between races... if you think there's a drain somewhere, good luck... electrical gremlins are usually no fun
Edit: ^that would probably work too...
