Battery Good - won't start - Wrist Twisters
post #1 of 6 Old 09-13-2014, 09:06 PM Thread Starter
Hey all, my 2004 919 suddenly won't start. I get instrument lights and headlight, bike is in neutral, kill switch is in the start position. But, when I push the start button, nothing. The lights dim a tad, but no sound, no clicks, nothing. I thought for sure the battery was bad, but I had it checked out and it has full volts, even under load. Anyone else had this problem? Oh, I am able to bump start it, and it runs fine.
Thanks!
bhendron is offline
post #2 of 6 Old 09-13-2014, 09:12 PM
Check the starter switch, usually connection either gets dirty (flood and exercise with wd40) or the connection itself is bad due to melted/broken solder. Both are known problems
post #3 of 6 Old 09-15-2014, 07:21 AM
Eric's Avatar
I had that a few years ago. I had the battery check at the local garage and find out to have a internal fault. Battery replaced and all good.
Eric is offline
post #4 of 6 Old 09-15-2014, 10:39 AM Thread Starter
Hmm, thanks for the replies. I hope to dig into this tonight.
bhendron is offline
post #5 of 6 Old 09-15-2014, 03:18 PM
SGKukov's Avatar
be sure to post the result!
SGKukov is offline
post #6 of 6 Old 09-15-2014, 06:52 PM Thread Starter
Fixed! Bad contact in kill switch. I cleaned the contacts up with some electric parts cleaner and then touched them up with some dielectric grease. All good in the hood now!
bhendron is offline
