basic shit I just dont know... help! - Wrist Twisters
post #1 of 21 Old 02-12-2012, 08:33 PM Thread Starter
GreyHornet919's Avatar
So i want to adj my throttle cable , but on the bar the barrel adjuster is maxxed out.... where do I pull the slack out at? (like how to get there/ tank removal needed?)
also when you do a oil change is it on a center /or rear stand or just on your side kick stand?
GreyHornet919 is offline
post #2 of 21 Old 02-12-2012, 09:04 PM
TEXAN
MF1VE's Avatar
For the oil change, I use the side stand. That way, teh oil can fall into a little open channel, and then run into a pan. I hate getting oil on the pipes.
MF1VE is offline
post #3 of 21 Old 02-12-2012, 09:09 PM
sounds like you might want to get some aftermarket levers. there are some cheap knock off ones on ebay that people seem to like
post #4 of 21 Old 02-12-2012, 09:25 PM
Levers won't adjust slack in the cable, just the distance from the bar to where your fingers hit the lever.
If you have slack in the throttle cables, it might be time for new cables. Good luck with that, I hear it's a pita.
post #5 of 21 Old 02-12-2012, 09:50 PM
there's adjustments on the throttle body where the other end of the cables are attached to.
Pvster is online now
post #6 of 21 Old 02-13-2012, 12:28 AM Thread Starter
Pv has the same idea I do... just not sure how to get to that end of te cable. the one on the bar is maxxed out.
post #7 of 21 Old 02-13-2012, 06:02 AM
3dcycle's Avatar
lift the tank you should be able to do it with the tank on just tilted up
and counting
3dcycle is offline
post #8 of 21 Old 02-13-2012, 07:06 AM
Whoops. I thought he wanted the levers closer. My b
post #9 of 21 Old 02-13-2012, 09:10 AM
As far as oil changes go, I use the center stand. That's the only way I can get my oil pan under the bike.
As far as keeping oil off the headers, use tinfoil. You can mold the tinfoil to keep the oil off the headers and also drip the oil into your pan. When you are done, throw it out with the filter.
post #10 of 21 Old 02-13-2012, 09:14 AM
Hey GreyHornet,
Like others have mentioned, raise the front of the tank up and see if you can get in there...
Also, when you make your adjustments, shorten the cables as much as you can on the right side control, and then max out the adjustment on the throttlebody end, then adjust to fit on the bars.
FYI, you are the first person I've heard from on here that needs to adjust that much slack out...including my 9er, with 40,000 miles on it! what's the issue? are the cables worn out?
post #11 of 21 Old 02-13-2012, 02:09 PM
Total Awards: 17
big PITA to do as there is not much room for your fingers. It fact there is zero room for your finger, get long handle needle nose.
How many miles on the bike? Since you need to get there anyway, get new cables, do it once and forget about it for awhile.
zaq123 is offline
post #12 of 21 Old 02-13-2012, 04:09 PM
Drain oil on sidestand. Drain hole is on that side of the bike, so you'll get better drainage with it leaned toward the hole. I also use the tinfoil on the headers. Think that was one of the first tips I picked up here and put to use right away.
jay313 is offline
post #13 of 21 Old 02-13-2012, 06:36 PM
I drain on the side stand too, don't need tinfoil on the headers down near the drain plug unless it's real windy. For the filter, this funnel makes the filter change a breeze
post #14 of 21 Old 02-13-2012, 08:43 PM
Batman
velodesign's Avatar
Aren't you supposed to run your engine a bit prior to change?..doesn't that want to melt that plastic funnel? Maybe I'm doing it wrong :-(
velodesign is offline
post #15 of 21 Old 02-13-2012, 09:23 PM
Yep, I drain from the plug first and by the time I get to the filter change , the headers have cooled down.
post #16 of 21 Old 02-14-2012, 12:54 AM
I usually change oil on a cold motor...
secondchance is offline
post #17 of 21 Old 02-14-2012, 06:43 AM
Batman
velodesign's Avatar
Really? Bone cold motor? Hmmm. Here's my routine now that I think of it. Go for ride, park it. Grab chain lube, spray and walk. Grab tin foil, touch header, still warm, crack oil pan bolt, let it drain, crack filter, watch it drain, walk away and get yelled at by my wife for stealing her tin foil, come back and fill.
So your pan probably works great, would save me an earful from the wife to boot. I'll have to try that next time.
post #18 of 21 Old 02-14-2012, 07:31 AM
Hahahahaha that whole post was awesome
post #19 of 21 Old 02-14-2012, 08:04 AM
wait..... you dont remove the oil pan bolt, you just crack it? and then you dont even replace it?! also, you just crack the oil filter but not remove it? then you dont replace it? how do you keep oil from spraying out of the cracks in the drain pan bolt and oil filter????
post #20 of 21 Old 02-14-2012, 02:05 PM
Batman
velodesign's Avatar
Ugh. If I typed my whole process on my phone it'd explode and I forgot to add 4 beers in there too.
I swear I'm not a 4 year old when I postbut I hardly ever use my computer at home anymore after staring at a monitor for 9+ hours a day...but I need to curb my wristtwister addiction somehow.
post #21 of 21 Old 02-14-2012, 02:58 PM
i'm just bustin your chops!
