Bar-end mirrors installation - Wrist Twisters
 1Likes
  • 1 Post By Islandboy
post #1 of 8 Old 03-11-2019, 09:58 AM Thread Starter
Isaiah Wright's Avatar
So I was trying to install my eBay bar end mirrors on my stock handlebars, they're the kind that has an expanding nut on them. There was plenty of room on the left side, but on the right side, the part that the stock bar end weight screws into was out too far, with no room to put the expanding nut mechanism in. Any ideas on how to either push it in or remove it completely?
If there's not a good way, then I just have another excuse to purchase Renthal's.
Thanks!
Isaiah Wright is offline
post #2 of 8 Old 03-11-2019, 10:58 AM
I did a Google search. This popped up.
https://www.wristtwisters.com/forums...rts-31276.html
post #3 of 8 Old 03-11-2019, 02:56 PM Thread Starter
It might be different since it's on the throttle side? They say the tang is 12mm in and I can't access that far in. The clip at the end I was able to remove on the other side, but here its pretty stuck, and the plastic throttle assembly lip sticks out further so i can't get a great grip on it.
post #4 of 8 Old 03-11-2019, 02:59 PM
Can you remove the throttle tube?
post #5 of 8 Old 03-11-2019, 03:18 PM Thread Starter
I'd prefer not to, since that would require me to remove the handlebars, but I can if necessary.
post #6 of 8 Old 03-11-2019, 03:40 PM
You can just loosen handlebar mount bolts so the handlebar slides over or release cables and slide throttle tube off that way. Good time to lube cables and tube.
post #7 of 8 Old 03-11-2019, 04:16 PM Thread Starter
Even if I get the throttle tube off, will that help in getting the weight nut out? Does it just come down to getting the retaining tang out?
post #8 of 8 Old 03-11-2019, 04:29 PM
I'm not sure if that retainer tag does need to be bent down or the grips removed.
In that link I gave you, the last post by Doc. He says no need to remove grips. Just use large diameter washers between bolt and bar. Then turn bolt and back out the insert.
Isaiah Wright likes this.
