anyone run a 15t front sprocket ? - Wrist Twisters
post #1 of 11 Old 08-26-2011, 05:36 PM Thread Starter
MSF blacksheep
Ferris Bueller's Avatar
Ive been thinking about doing this. Any input?
Ferris Bueller is offline
post #2 of 11 Old 08-26-2011, 05:42 PM
Sixty-9er
edgecrusher4444's Avatar
Like wheelies?
"Grip it and Rip it!"
edgecrusher4444 is offline
post #3 of 11 Old 08-26-2011, 05:44 PM Thread Starter
MSF blacksheep
Originally Posted by edgecrusher4444 View Post
Like wheelies?
Is it really that big of a change? I would keep the rear at 43.
post #4 of 11 Old 08-26-2011, 05:45 PM
Sixty-9er
yes
post #5 of 11 Old 08-26-2011, 05:49 PM Thread Starter
MSF blacksheep
Hmmm.... what kind of impact does it have on cruising rpm? Mine sits right at 4k at 65 now.
post #6 of 11 Old 08-26-2011, 06:42 PM
ariannasdaddy's Avatar
919.org 919/Hornet 900 Owners Group check the gearing spread sheet
Arte et Marte
ariannasdaddy is offline
post #7 of 11 Old 08-26-2011, 08:53 PM
I have a Internet friend running that on her 919. Turned it into a screaming power house she said - basically your revs will increase about 500rpm for any given top gear speed so it is a lot more dramatic when you snap the throttle. She loves it in the hills.
Me - I find the stock gearing pretty perfect to a wide variety of riding environments and styles.
You can try it out without changing anything for open road cruising - go for a ride and keep the bike out of 6th - ie use 5th as a top gear on the open road - that is what cruising will be like. Obviously each lower gear will have a similar affect and 1st will be more wheelie prone.
post #8 of 11 Old 08-26-2011, 08:55 PM
Just factor the revs by the change in ratio to find out what the new revs will be.
15/16 then invert to get 1.066
4000 x 1.066 = 4267 revs at the same speed but with a 15 tooth instead of 16.
You don't need XL sheets and complex math to be able to figure this out in a flash.
post #9 of 11 Old 08-26-2011, 11:16 PM
i bought a 15t front on ebay shortly after i got my 919.
turned the thing into a wheelie machine, it DEF makes a decent difference. i quickly switched back to the stock 16t because i could be smoother in 1st and second in the twisties... and being smooth is key.
Tho i must say is was hella fun!
Hit me up with a pm... like stated i got a 15t that has maybe 1k miles on it.
post #10 of 11 Old 08-27-2011, 12:35 AM
Smooth is the new fast.
post #11 of 11 Old 08-27-2011, 07:27 AM
A couple of years back there were a one or two 15's flooting around here. Guys would try them out and ship them to the next guy who wanted to try.
