Anyone reuse the fuel pump gasket before? - Wrist Twisters
post #1 of 11 Old 06-06-2014, 07:17 PM Thread Starter
redline919's Avatar
I'm finally getting around to putting the new tank on that's been sitting in a box for 8 months. Just wondering if I should go ahead and order a new gasket? Or will I be ok? I have reused them before on GSXR bikes. Just want some feedback from experience. Thanks.
redline919 is offline
post #2 of 11 Old 06-06-2014, 08:34 PM
I've had the original gasket in and out of the 2002 I recently got ride of at least 3 times. Even with a broken stud it still holds.
post #3 of 11 Old 06-06-2014, 10:27 PM
+1, done more than that and still holding just fine. Just make sure you don't tear it.
post #4 of 11 Old 06-07-2014, 04:58 AM Thread Starter
redline919's Avatar
Awesome. Thanks guys.
post #5 of 11 Old 06-07-2014, 05:27 AM
Follow the torque spec! If your wrench starts out close to the value don't trust the wrench. I replaced 1 stud, said screw it and rolled with 1 broken when I snapped the next one.
post #6 of 11 Old 06-07-2014, 05:33 AM Thread Starter
redline919's Avatar
Will do, thanks for the heads up!
post #7 of 11 Old 06-07-2014, 06:56 AM
I snapped a stud on mine as well on reinstall after painting my tank. Go easy on them.
post #8 of 11 Old 06-07-2014, 08:53 AM
Ginger-prick
EatDirtFartDust's Avatar
My old tank had a broken stud and it didn't leak.
Transferred the pump with old gasket to my new tank and was very careful not to overtorque.
No leaks so far.
2007 Honda 919.
EatDirtFartDust is offline
post #9 of 11 Old 06-07-2014, 08:54 AM
Ginger-prick
Lock-tite
Hand-tight
I've learned the hard way on my car's intake.
2007 Honda 919.
post #10 of 11 Old 06-07-2014, 04:52 PM Thread Starter
redline919's Avatar
Ok tank installed. All is good. Thanks for all of the advice. I already ran a whole tank a gas through it today.
post #11 of 11 Old 06-09-2014, 06:47 AM
woodyeee's Avatar
Its all about feel, I very rarely use a torque wrench except for the head gasket, but heres a tip for you guys. Where possible use one of the small socket sets with the smallest ratchet as that will help you to put less leverage on what you are tightening up.
woodyeee is offline
