Antifreeze - Wrist Twisters
post #1 of 11 Old 07-28-2012, 04:16 PM Thread Starter
mikero's Avatar
Antifreeze
My cb900f was running hot on the highway which you know is not normal. I am not too mechanicaly inclined, but knew that I hadn't checked the antifreeze in a while, so I bought some Prestone Dex-cool which is for cars. Is this going to be a problem? Bike cooled down for a while, but soon appeared hot again. It's home now and I will chwcl tomorrow and go to mechanic Monday. Any suggestions.
mikero is offline
post #2 of 11 Old 07-28-2012, 04:23 PM
The amount of coolant in the system in hot weather is always going to be more of a factor than the specific type of anti-freeze you add to it....
K1w1Boy is online now
post #3 of 11 Old 07-28-2012, 04:26 PM
But no matter what you do, do not put Dex-Cool in your system. That crap will clog up your system. If you need something on the pinch, just use distilled water. How old is the coolant in there now?
post #4 of 11 Old 07-28-2012, 05:09 PM
+1 If you mix the orange Dex-Cool with regular antifreeze it will turn to a gel and stops coolant flow.
Can I Add the Green Coolant to the Orange Coolant?
You can put the regular Green/Yellow Prestone in if it doesn't contain Silicates. Should say on the label.
Also when you fill the cooling system, do it from the radiator cap (you have to raise the tank). If you only add it to the overflow tank under the seat, the system isn't full.
post #5 of 11 Old 07-28-2012, 05:45 PM
bocomomark's Avatar
I had a truck with the orange dexcool in it, and in my case I did have some seals get really soft and gooey... So my experience lies in the "avoid it category".
And yeah, be ***REALLY*** careful about what coolants you mix with what, they are not all compatible any more, and It's my understanding that even if they swear up and down to be compatible, you should be careful. I've been running Some blue coolant made by Honda for Honda cars. No problems in two years, locally available and relatively inexpensive.
Whatever you do, I suggest you flush out the system as best as possible and start over with whatever coolant you decide on. (dont mix it in)
bocomomark is offline
post #6 of 11 Old 07-28-2012, 07:47 PM
Hastatus Prior
TheBeeDeeGee's Avatar
When you say 'running hot' where is your needle at when cruising on the highway? I only ask because I thought mine might be running a little hot as well lately (although it has been 98-100 outside) but I wanted to see if what I think is hot is actually OK.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #7 of 11 Old 07-28-2012, 08:02 PM
redline919's Avatar
Flush and fill with Engine Ice. Bleed the air out of the system. Is the fan coming on? Also could b thermostat sticking or coolant temp sensor. And yes Dexcool is the worst antifreeze ever made. Does it get in the red on the gauge?
redline919 is offline
post #8 of 11 Old 07-28-2012, 09:17 PM Thread Starter
mikero's Avatar
I don't know but will have system flushed Monday. It never reached red, but was geting close and it normally runs real cool. Fan came on after ading antifreeze. Will not ride tomorrow and will bring to mechanic Monday. Mechanic is about a mile away.
Thanks for the help. It's good having you guys to go to.
mikero is offline
post #9 of 11 Old 07-28-2012, 09:27 PM
If you're moving past 40 on the freeway, you shouldn't be going past the halfway mark. In traffic it's normal to get past the temp logo specially in the hotter months.
And even if your car or truck (I think it's mostly GM) calls for dex-cool, I'd think about flushing it out to green. Google around and you'll see a lot of system failures because of the orange stuff
post #10 of 11 Old 07-28-2012, 09:31 PM
redline919's Avatar
You should have them put Engine Ice coolant in. It's the best in my opinion
post #11 of 11 Old 07-28-2012, 10:05 PM
Got dyno graphs?
