Another shifter bolt bites the dust. Need size of bolt. - Wrist Twisters
post #1 of 6 Old 05-30-2015, 10:13 AM Thread Starter
So, I was riding down the highway, downshifted and all of a sudden I'm dragging my shifter. I managed to find the bolt but the threads at the start of the bolt are boogered up enough that I can't get it to thread in.
So, does anyone know the dimensions so I can run up to Lowe's and grab a replacement. Anything else I need to know?
Thanks!
sradwar is offline
post #2 of 6 Old 05-30-2015, 10:31 AM
LIVE FOR THE PROCESS
Nesty's Avatar
what bike?
I haven't been around this site much over the past couple of years but there used to be a lot of 919s. If that's the case, my manual has all of the clutch/gearshift linkage bolts as either 6 or 8 mm thread diameter except for the clutch center lock nut (22)
I would just hit lowe's and get a few across the probable range of what you'll need. the ones you don't use, you'll probably end up using for something else.
Nesty is offline
post #3 of 6 Old 05-30-2015, 10:31 AM Thread Starter
Originally Posted by Nesty View Post
what bike?
2004 Honda 919
sradwar is offline
post #4 of 6 Old 05-30-2015, 10:41 AM
Nesty's Avatar
Nice!
at one point, you used to be able to find the entire shop manual on this site relatively easily.
Granted, nakeds have gone to another level over the years, but my 9er is still as good a daily driver as I could ever ask for.
Nesty is offline
post #5 of 6 Old 05-30-2015, 04:23 PM
crimedog's Avatar
Sounds like what you really need is some loctite!
08 DR-Z400SM
WFOATT
crimedog is offline
post #6 of 6 Old 05-31-2015, 02:28 AM
Some blue loctight on it will stop it from coming undone.
07919Dave is offline
