Another.... do I need to replace my battery? - Wrist Twisters
post #1 of 6 Old 01-27-2013, 08:16 PM Thread Starter
Hey All.
So my battery died a couple of months ago when I leaving to go home from work. It was coldish out (~40*f) and I had my HIDs on when starting the bike, so I thought it was that. I was able to jump it but it happened again the following week. I had been doing sporadic testing of the battery, and yesterday I finally bought a cheap multimeter.
These were my results:
13.5 volts when fully charged by battery tender.
12.5 v under full load (lights, not running)
14.5 v with engine running.
About 30 seconds (maybe less) of starter motor going (engine not running) before the battery dies and the solenoid switch starts clicking (does it have a solenoid?). Voltage dropped from sub 11 v to almost nothing. Also it took only about 30 minutes to recharge that dead battery to full using the battery tender.
It looks like I need a new battery, but I guess I need some affirmation before I drop $130 for a Shorai battery.
Any comments?
Thanks in advance.
2003 919
Yoshimura TRS
Power Commander
Renthal UL
Tower is offline
post #2 of 6 Old 01-28-2013, 02:37 AM
Yep, I'd say you need a new battery.
post #3 of 6 Old 01-28-2013, 06:54 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
I concur. Looks like a new battery is in your future
ST-DocLizard1 is offline
post #4 of 6 Old 01-28-2013, 07:55 AM
"Whose ABBA ZABBA?"
14.5-15.5 somewhat normal alternator output.
If you leave it on full load, not running, how fast does the voltage drop?
Cutting to the chase, how old is your battery to begin with?
Also: Folks, a multi meter is an invaluable item and addition to your shop.
I suggest not sparing the money and getting a quality one for the long run.
I have had my Fluke 77 DMM since the mid 80's and it has served me well to this day.
In my opinion, the M1 rifle is the greatest battle implement ever devised.
General George S. Patton
post #5 of 6 Old 01-28-2013, 09:13 AM Thread Starter
[QUOTE=Bigdaa;538149]14.5-15.5 somewhat normal alternator output.
I got the 9er last season and I dont know how old the battery is. Its a Motocross Platinum, which I think is a mid tier Yuasa AGM battery. I dont tend it but during the riding season I ride it every weekend.
From memory, I think the voltage dropped quickly from 13.5 to 11.5 and stayed there for a bit. I recall seeing it drop 0.01 volts from there every couple of seconds or so. I have really bright HIDs. I started it before it dropped too much because I hadnt done the alternator portion of my diagnostic.
2003 919
Yoshimura TRS
Power Commander
Renthal UL
Tower is offline
post #6 of 6 Old 02-18-2013, 01:34 PM Thread Starter
I finally got the Shorai battery. Model no LFX14A4-BS12. Its real light but it's about the same size as my old one. I thought it'd be much smaller. Interesting instructions: if storing for a while, keep it refrigerated. And most interesting... Do not allow charge voltage in excess of 14.8 volts. Interesting because my alternator puts out 14.5 volts. Mmkay. Little close for my comfort but OK.
Let's see what happens after I install it.
2003 919
Yoshimura TRS
Power Commander
Renthal UL
Tower is offline
