Another 919 with problem on low rpm - Wrist Twisters
post #1 of 22 Old 07-21-2012, 02:13 PM Thread Starter
Hello guys. Yesterday I did starter valve synchronization, because I had a poor performance at idle speed.
After synchronization, I went to ride, and noticed the failure to 3-3.5 rpm bike jerks, but after 3-3.5 rpm - good, easily power wheelie)).
In what may be the problem? Today I replaced the spark, but the problem remained.
I read couple threads with seems problem, but think I have another problem.
hookups is offline
post #2 of 22 Old 07-21-2012, 02:32 PM
Check the fuel pressure regulator, what you have is a classic symptom. Search here for it, there're a couple threads.
post #3 of 22 Old 07-21-2012, 03:00 PM Thread Starter
Thanks for the reply!
Ohh shit! FPR costs 250 $ in Russia: D. Please, tell me, i can riding with bad FPR? Of course I will order new FPR, but it's will arrive after 2-3 weeks.
Question: Why FPR is dead? this may be a sudden or I helped him to die?
hookups is offline
post #4 of 22 Old 07-21-2012, 03:13 PM
I need to start exporting FPRs to Russia.... LOL
FPRs can just become faulty. It can start with a small issue only noticeable under load, but usually there are tell-tale signs. Excessive amounts of exhaust smell, poor running (like you mentioned), fouled plugs, etc.
You did not help it become faulty by riding and filling gas like normal. If you've been using bad fuel additives, that may be an issue but usually they just go bad on their own.
post #5 of 22 Old 07-21-2012, 03:17 PM Thread Starter
Means this is a coincidence), I thought I messed it when did synchronization.
hookups is offline
post #6 of 22 Old 07-21-2012, 06:27 PM
check my post ...
kiss method on the 919 (Keep it simple stupid)
First check the battery cables.
Next check the major ground lead thats under the tank on the throttle side of the backbone on the frame.
Does the bike crank over as fast as it normally should? If so then your batt is fine... if not then replace.
If both those are good, then its likely you have the one and really only part failure known to the 919 which is the fuel pressure regulator.
You can check this a couple of ways.
1. With the bike cold, start it up, feel the outer cylinder headers vs the inner cylinder headers.... if the inner's are cold compared to the outers then you have a FPR problem.
2. Pull the spark plug on cylinder #2 (that would be the second cylinder from the clutch hand side of the bike) ... if its black, FPR problem.
3. Pull the vacuum line on the FPR, if there is fuel dripping or smell of fuel in the line the fpr has gone bad.
post #7 of 22 Old 07-21-2012, 07:11 PM
Chief 10 Beers
wgrady's Avatar
I was wondering if the FPR problem was related to Ethenol in our gas in America. If his does turn out to be the problem then I guess I will back off that theory? Would it be cheaper for him for someone to send him one from USA?
There are bold motorcyclists and old motorcyclists, but (OK) there are few old bold motorcyclists
wgrady is offline
post #8 of 22 Old 07-22-2012, 10:43 AM
OP if it is your FPR and want to save some.... we can set something up. its only 17 usd for me to ship an FPR via usps flat rate box from usa to russia.
post #9 of 22 Old 07-22-2012, 11:24 AM
blur
drewvir's Avatar
service honda price $60 + ups$17 =
drewvir is offline
post #10 of 22 Old 07-22-2012, 11:36 AM Thread Starter
Sorry, i don't understand. You have the used FPR for me?
hookups is offline
post #11 of 22 Old 07-22-2012, 11:39 AM
blur
drewvir's Avatar
no brand new if he orders from honda dealer then sends to you via www.ups.com
drewvir is offline
post #12 of 22 Old 07-22-2012, 11:50 AM
no no.
What i was purposing is for me to order the FPR, have it shipped to my house, then ship it to you.
price of part + ship to me + ship to you. (50-60 + 10ish + 17)
post #13 of 22 Old 07-22-2012, 12:03 PM
blur
drewvir's Avatar
what a guy
drewvir is offline
post #14 of 22 Old 07-22-2012, 12:07 PM Thread Starter
no no.
Thanks guys for help, you are cool!
Not to worry, I can buy myself FPR in USA.
For example here:
Motorcycle Parts | OEM Motorcycle Parts | Cycle-Parts.com
hookups is offline
post #15 of 22 Old 07-22-2012, 04:22 PM
ah cool.
Well i would determine that it is infact the FPR before ordering..... see my post above.
post #16 of 22 Old 07-22-2012, 05:05 PM
Hold on there!
The FPR may be the problem, but until it's tested by either finding liquid fuel in the vacuum hose or at least a fuel smell you are "shotgunning" with a new part and hoping it works. That can get very expensive very fast.
Number one rule of sudden malfunctions: the last thing done to it is usually the cause. All it takes is a two vacuum lines crossed, an overadjusted idle bypass valve (which should be active only when the "choke" knob is pulled out anyway) which is still open slightly with the choke closed, or any of a bunch of other minor things that could cause a problem.
My advice is to recheck all your work in reverse order, preferably with a service manual right in front of you, and odds are you will find one of those minor mistakes. If not, go ahead and start ordering parts.
post #17 of 22 Old 07-22-2012, 08:55 PM Thread Starter
This is old spark plugs
1-2 cyl. more heat than 3-4.
hookups is offline
post #18 of 22 Old 08-07-2012, 11:49 AM Thread Starter
The spark plug on cylinder # 2 is "oil" black.
It's time to order a FPR.
Thanks all for replies.
hookups is offline
post #19 of 22 Old 08-09-2012, 07:48 PM
I have had this same problem too from 3-4.5k rpms. It was so bad I couldn't even ride it home from work. So I parked it for 5 weeks while I researched the problem and got a new FPR. Just put it on and it is sputtering, jerking, bucking and will not even idle. It sounds like it is supremely clogged up. Anyone have any ideas for me to try and get this running again? Gas is starting to go back up!
Rubber Side Down!
brownjellytrail is offline
post #20 of 22 Old 08-09-2012, 10:31 PM
Load test the battery. Check for vacuum leaks. If you can, draw some fuel from the bottom of the tank and put it in a glass jar. Let it 'settle' over night and check for water in the fuel (I'm assuming you park outside.) Have you pulled the plugs and taken a look at them? How about grounding?
post #21 of 22 Old 08-10-2012, 02:31 AM
+1 for testing the battery.
post #22 of 22 Old 08-10-2012, 11:52 AM
anything with the 919.... like i have said before and will say again.
KEEP IT SIMPLE.
The worst thing that happens on these bikes is the FPR.
Beyond that, make sure your battery is good and major ground connections are sound.
