Advice please if you have time...Mice fail - Wrist Twisters
post #1 of 67 Old 04-09-2013, 09:49 AM Thread Starter
Dinh919's Avatar
Hey guys, so, pulled the 9er out of the garage after winterizing, and for the first time since i've had er , no start.
2002- was on tender, never had any issues. Full tank of gas, starter on, neutral. Garage was crowded with stuff but nothing leaning on bike, or anything that could have damaged during storage. It was next to a couch basically for 3 months.
I put switch to on and didn't hear the FI motor spinning. That was my first uh oh. Strong battery, lights, signals, rear lights, signals all working. Hit starter cranked strong, but never turned over. At risk of burning out starter, tried a few times. also noticed when i hit starter heard a sort of 'pop'. not firecracker pop but like an air pop maybe like a lightbulb popping (fuse?)
I believe FI light goes out, then blinks maybe 2x.
Opened seat and notice some mouse crap around the wires: (see pics)
The mice, usually after not riding for a while, they'll set up in the intake, and stuff it with paper towels or whatever. Opened that up was completely full.
Tried again for fun, still no dice, same issue so i stopped seeing that I knew the FI not pumping gas in.
Am I right to assume wire short and maybe blew a fuse? I'm not "electrically" savvy so how hard will this be to fix, and fix as to not leave me stranded? Can I just tape up wires as to prevent short or do i have to splice etc? What's the best place to order fuses? Sorry for ramble. I'll keep searching too but if it's easy fix please let me know.
Anything else I should check that maybe got nudged by the couch and tight packed garage? I've been taught "simplest cheapest" first and going thru my checklist kickstand not issue as starter firing, i have plenty of gas etc so pretty sure it's mickey and his friends.
Dinh919 is offline
post #2 of 67 Old 04-09-2013, 09:56 AM
Looks like the mice chewed through a few wires in that harness. I don't recall a white connector on my 9er... what part of the bike am I looking at? Is that wiring stock?
post #3 of 67 Old 04-09-2013, 09:59 AM
That's the ecu? Time.to take it all apart to inspect the wire harness. Also check fuses but not until you confirm no damage.to the harness.
post #4 of 67 Old 04-09-2013, 09:59 AM
"Whose ABBA ZABBA?"
Expose and clean all areas affected so you can ID all chew throughs and repair.
Charge the battery out of the bike to give you the room to move around and look. Pull up the tank and check all hoses and air lines, too.
You have some work ahead.
In my opinion, the M1 rifle is the greatest battle implement ever devised.
General George S. Patton
post #5 of 67 Old 04-09-2013, 10:05 AM Thread Starter
Dinh919's Avatar
that is the wire area closes to the tail of the bike, on the right side. Yes stock to all my knowledge, no PCII or anything on bike. I understand I have work ahead, but, would it be safe to say on a hunch that the wires may have shorted themselves out?, thus not firing the fuel pump?
Everything else electrically on bike appears to be working fine (blinkers, lights, trip odo, etc). Just want to narrow the issue as best as possible. I'll clean out that area as soon as I can.
Dinh919 is offline
post #6 of 67 Old 04-09-2013, 10:06 AM Thread Starter
Dinh919's Avatar
Thanks- I understand I have work- hmm...seems to me the problem is electrical and bike isn't getting fuel via pump. What does the blinking FI light 2x mean? Does that specify a specific error? I'm not great at electrical work so trying to determine if this is something i can do or it's above my head.
Dinh919 is offline
post #7 of 67 Old 04-09-2013, 11:17 AM
HornetMan's Avatar
The first thing I'd do is to take the damn couch out in the yard, douse it liberally with gasoline and light it. When the flaming rodents take off across the yard whack em good with a shovel. This won't get your bike started, but it will put you in the proper frame of mind to work on it knowing the little suckers won't return to do more damage.
"Keep on 9-in"
HornetMan is offline
post #8 of 67 Old 04-09-2013, 11:24 AM
If you look closely in your first picture, you can already see exposed wiring that got chewed through. Focus on repairing those wires, examine surrounding area for any other potential wire repair needs, then check for fuses and replace if needed, then try firing up the bike again.
Pvster is online now
post #9 of 67 Old 04-09-2013, 11:37 AM Thread Starter
Dinh919's Avatar
Yeah , noticed those -.... i'll try to clean it out, and repair first for sure. Does anyone know if the FI pump is directly correlated to a specific colored wire/fuse seeing that everything is working fine otherwise?
Dinh919 is offline
post #10 of 67 Old 04-09-2013, 12:19 PM
You need to drop the under tail and pull the tank and inspect the complete full harness. Just because you think the fuel pump is the only issue, odds are it's not. With the exposed wires at the ecu & possibility of exposed wires elsewhere by fucking around with it turning power on and off you could easily...
- create a short
- fry the ecu
- burn up some wires in the harness
- fry other sensors etc.
- start a fire
All of which could be expensive to fix and a real pain in the ass to sort out. Just pull the battery out, pop off the tank and tail faring and drop the undertail, take your time and look the harness over for damage .... by rushing this or doing it half ass you could be creating more problems then fixing them.
As far as the fuel pump goes, have you checked the pump connector under the tank for wire colors or damage?
post #11 of 67 Old 04-09-2013, 01:32 PM Thread Starter
Dinh919's Avatar
- create a short
- fry the ecu
- start a fire
Haven't inspected the tank area or removed yet. I agree slowly and surely is better, and I'm not too proud to admit it could be above my skill level. Most intensive thing I did was put on my exhaust.
Wouldn't a fried ECU though mean other things also not working? I'm just trying to best isolate a few things first.
Dinh919 is offline
post #12 of 67 Old 04-09-2013, 01:47 PM
Someone get this dude a wiring diagram! Fix the ecu connector wires first. That could/probably fix everything
post #13 of 67 Old 04-09-2013, 01:49 PM
its probably just a chewed through wire but that whole harness needs to have a once over... those rats did some work... bastards.
BTW... pin number 6 on the main black connector is the one that fires the fuel relay... its a Br/Bl (brown wire blue stripe i assume) wire.
from there the wire that powers the fuel pump is a brown wire.
post #14 of 67 Old 04-09-2013, 01:57 PM Thread Starter
Dinh919's Avatar
i'll search for it..sorry i know a lot of you guys are way more savvy at this than me. so if u have the time to help great, and the posts have been helpful just getting eyes on it. i'll keep looking in the meantime (and agree w u).
Dinh919 is offline
post #15 of 67 Old 04-09-2013, 01:57 PM Thread Starter
Dinh919's Avatar
great, exactly what i was looking for in terms of the wire color...thanks man.
Dinh919 is offline
post #16 of 67 Old 04-09-2013, 02:19 PM
After trying all suggested ideas, the next step is to get a cat. No more problems with mice or birds.
post #17 of 67 Old 04-09-2013, 03:08 PM Thread Starter
Dinh919's Avatar
aready have 2, but they are indoor .they may need to have a few slumber parties in the garage.
Dinh919 is offline
post #18 of 67 Old 04-09-2013, 03:52 PM
Rich Jura's Avatar
Had the same thing happen to me, for some reason I pulled the seat before I attempted to start it. Patched the harness and it's been good for a couple of years now. When winter rolls around I take the seat off and store it in the house (seat) that discourages the little bastards, I also take cotton gloves filled with moth balls and place them all over the bike. So far so good ;-)
Rich
Rich Jura is offline
post #19 of 67 Old 04-09-2013, 03:59 PM
akscare's Avatar
I got the same problem, Mice chewed some wiring but among the big bulk wire cluster (Wraped under black tape), I have tried sealing all chewed one with insulted tape but I didnt get chance to test it out as its in my friend's garage and my battery was also gone. I want to take it to dealership to be on safe side. Any suggestion on good service dealership in Maryland-DC area???
akscare is offline
post #20 of 67 Old 04-09-2013, 04:41 PM
Toll Runner
str8ghtjacket's Avatar
By the looks of it that bike needs to be cleaned anyways Take your time and do a through job and Im sure youll be up and riding in no time. I had a mouse problem once. girlfriend was keeping the dog food in the garage and the boys would spill it, mice were coming for the scraps. Eliminate any food sources, and get some mouse traps. The snap kinda not the Im going trap you and let you loose kind because they will just come back. I killer 12-13 when we had a problem. Those things can climb vertical walls. I do like the set the couch on fire and shovel idea tho
str8ghtjacket is offline
post #21 of 67 Old 04-09-2013, 07:28 PM
"Whose ABBA ZABBA?"
That pop sounds like a nice bit of current arcing across a couple of wires.
This should result in a blown fuse.
HeliMech is speaking the truth, not like the double tongued Blue Coats.
You need to spot the points of the short and assess the extent of conductor involvement. Heck, it could be as easy as blowing a fuse from a powered line to ground and have not a dman thing to do with the ECU!
Nothing is going to get rid of the worry until you start the troubleshooting procedure or you drop it off at he shop and the mechanics hourly rate starts ding ding dinging the personal cash register.
If what is exposed has been eaten, I think more is instore around the corner and down the block, so to speak.
You did good with the photos, so keep it up and post the progress so the knowledgeable ones here (not me) have the best to go by to help you.
post #22 of 67 Old 04-09-2013, 08:52 PM Thread Starter
Dinh919's Avatar
Thanks guys. I'll keep you updated on the progress...not glad, but glad some others have gone thru this. I got home a bit late from work and by the time kid was in bed it was dark, and I was tempted to tinker, but knew that'd mean me in a dark garage and not taking my time. I am going to read up and take my time this weekend.
Motorcycle class taught me to "never rush" and I'll make sure to not i this case even when I'm not riding
I've never taken the tank off though, so that's the main thing I'm nervous about. But I'll start at the rear and work my way around. I've taken faring off before when I put my exhaust on so I'll give it a slow look soon.
Thanks dudes.
Dinh919 is offline
post #23 of 67 Old 04-09-2013, 09:59 PM
If you're that worried about the tank, you can just prop it up to allow yourself a better view and help you decide if the tank indeed does need to come off.
post #24 of 67 Old 04-10-2013, 12:45 AM
StormSurfer
Whiplash97's Avatar
Video of the couch burning mouse stomp!!?
Look up 5 Gal. Bucket and peanut butter mouse trap, it works great! You'll have a bucket full of drown rats in the morning
:buell:
Whiplash97 is offline
post #25 of 67 Old 04-10-2013, 12:54 AM
StormSurfer
Whiplash97's Avatar
Here we go:
Looks like this in a real application:
The snap traps work but you could end up being made a fool of like this little bastard did to his pursuer
The bucket works, and there's no escape then ya just take em out with the rest of the trash
:buell:
post #26 of 67 Old 04-10-2013, 01:35 AM
LOL a 'better mouse trap' Too cool!
Whatever you do, don't use that poison stuff, the rats die and stink for weeks!
KarlJay is online now
post #27 of 67 Old 04-10-2013, 04:59 AM
Do you have a copy off the service manual? Someone shoild be able to lknk you yo the "drop box" where tgere is a pdf copy. It shoes the complete harness layout and explains pretty well.
You dont have to remove the complete tank right away, just loosen the lower pinch bolt (aft/lower) and slide it back, then loft the front up and prop it up with a chunk of wood. You can at least get a look at most of the harness with a mirror and flash light.
Starting at the tail is a good idea, just start by pulling off the pipes and plastics until you get to the bare undertail tray. Then you can loosen off the the rear bolts on the undertail tray and pull/fish out the ecu and most the tail harness and relays.
Check it over. Careully use a razor blade to cut off any wrapping or covering to expose the damaged areas. Pick up a small spool of similar gauge wire & splice, solder and heat shrink and damaged wires.
Just do one wire at a time, the key is not to make a wire to short that it won't allow the harnees to be routed properly or connected. Good luck, keep the pics coming.
post #28 of 67 Old 04-10-2013, 07:24 AM Thread Starter
Dinh919's Avatar
i actually do have a PDF of the shop manual so was reading it last night. I wish i could take a day off and just fix it! going to read the manual make sure I have the right tools and extra wire and dive in full Saturday morning. rookie question, but Should I leave the battery connected so I can test current or disconnect first? clean and splice, then reconnect?
Dinh919 is offline
post #29 of 67 Old 04-10-2013, 07:50 AM
I would remove the battery and the ecu & relays. Fix the damaged wires then reinstall and test the system. I wouldn't worry about putting power back on and trouble shooting, until you are sure its all cleaned up.
After the harness is repaired, check all the fuses and connectors. Then throw power on and start to trouble shoot.
post #30 of 67 Old 04-10-2013, 08:18 AM
"Whose ABBA ZABBA?"
Your job is to repair all the physical damage you can find and then begin to make full up powered measurements.
Make sure to ohm out the fuses to see if they are blown. This assumes you have access to a Digital Multi Meter.
post #31 of 67 Old 04-10-2013, 08:29 AM
Originally Posted by Whiplash97 View Post
Here we go:
I think I'd put some water in mine. Around here the mice can really jump. I'm sure they could jump out of a 5 gallon bucket. I'd rather make sure the little f-ers are dead. My cat does a good job of killing them and our rabbits.
post #32 of 67 Old 04-10-2013, 09:23 AM
StormSurfer
Whiplash97's Avatar
WTF!? Bro there is suppose to be water in the bucket about 4" of water is plenty to snuff out the typical mouse
:buell:
post #33 of 67 Old 04-10-2013, 10:14 AM
8" of water works.wonders.for.chipmunks ...
post #34 of 67 Old 04-10-2013, 01:48 PM
How much water for prairie dogs and rabbits? We have more of them then mice. No rats here in Alberta.
post #35 of 67 Old 04-10-2013, 01:53 PM
Total Awards: 17
this is the best mouse trap, period. HomeDepot sells them.
Ortho Home Defence Max.
zaq123 is online now
post #36 of 67 Old 04-10-2013, 03:49 PM
i love the water in the bucket idea... Genius.
post #37 of 67 Old 04-10-2013, 05:00 PM
carotman's Avatar
The best thing you can do to the ECU harness wires is to pull them out of the connector and add shrink tubing to the chewed areas.
If the copper has been eaten by the mice, replace that part of the wire and add shrink tubing too.
This will ensure wire integrity in the long run. You can even get shrink tubing that has some kind of glue in it. It will seal that area of the wires for good!
carotman is offline
post #38 of 67 Old 04-10-2013, 07:46 PM
StormSurfer
Whiplash97's Avatar
Ok, I'm gettin bored with this....this is your chance!!! Throw that rat bitten pile in the lake and go get a Gixxxer
:buell:
post #39 of 67 Old 04-13-2013, 10:26 PM Thread Starter
Dinh919's Avatar
So i took tail off and everything and got the wiring harness/ecu out and cleaned up. Good news if any is that no more damage, checked under tank and that is good. They mainly lived in the intake, and seems like one rebel mice hung out in the seat. Before i disconnected battery i turned key to on and got FI 1 second light, and 3x fast blinks- which translates to "13"blinks according to the manual. Which i think according to shop manual means it's injector 2 has short or faulty.
There are two broken wires- pink/blue and green pink. I got them cleaned, re stripped and got some connectors and am gonna finish splicing and insulating them tmrw, reinstall battery and hope I get fuel in the engine and she starts. I wanted to finish so bad, but ran out of time cause my kid woke up, and didn't want to rush it.
Last I checked a few days ago, everything else was working so hope this does it. I have spare fuses in case. I'll report tmrw on how i do. thanks all.
pics of two chewed wires
Dinh919 is offline
post #40 of 67 Old 04-13-2013, 10:28 PM
I bet she fires right up after you get those wires repaired. Good luck tomorrow!
