Adding a charge/jump/access port to a battery. - Wrist Twisters
 1Likes
  • 1 Post By sugar
post #1 of 17 Old 02-04-2018, 08:40 AM Thread Starter
I have a float charger from Harbor Freight and a 12V port that I was thinking of adding to my tank bag.
So what I have in mind is to make an access port to the battery. Maybe add wires direct to the battery and mount them so that I can have access to the 12V without having to take off the cover.
I have spare cig lighter port and adapter. Bit bulky for a motorcycle, but I also have the USB adapters for that and cig ports are common.
Anyone do a project like this? We all need power to our tank bags, so having it built in would be an advantage.
post #2 of 17 Old 02-04-2018, 09:15 AM
My tender came with an SAE connector that connected to the battery at the terminals and is easily exposed without taking covers off. Is that the kind of thing you’re after?
What I would like is my little jump starter’s cord to have an SAE connection instead of just the alligator clamps.
steev is offline
post #3 of 17 Old 02-05-2018, 07:14 AM
I have tons of power all over my bike. I have a set of leads running from the battery back to a terminal block in the back (just a basic one, nothing fancy.) I was having problems fitting the battery in the box with multiple wires run to it. I installed a relay that is switched by the taillight so I have both always on and switched power at the terminal block, plus a ground. Both are individually fused on the wire back to the battery. I can take some photos if you'd like, and could possibly replicate a few if people are interested. I then have a heated gear plug wired to the terminal block, which is installed in the black side cover below the seat. I also have a dual USB plug installed in the black rubber cover in front of the tank where the PAIRs pump used to reside, I have the wires running along the backbone below the tank back to the terminal block, and when I need to use them I just plug in and run the wire to my tank bag, but when not in use no one would know it's there. I also have my chain oiler wired to the terminal block.
post #4 of 17 Old 02-05-2018, 09:45 AM Thread Starter
I would like to see a few pics of that. I didn't know a chain oiler would be electric, who makes it and how's it work?
I like the idea of a few USBs to the bag, looking for a quick disconnect type if their is such a thing. I use an iPod and headphone amp. I also have an emergency light I'd like to rig up under the seat so I don't have to carry a flashlight.
post #5 of 17 Old 02-05-2018, 02:49 PM
I connected the charger harness that comes with a charger to every bike I’ve had - then I connect that to a cigarette lighter outlet on my handlebars. I keep the connectors intact so I can connect the charger down near the battery if I want. However, usually I just plug the charger into the cigarette lighter outlet on the handlebars using the standard adapters so available. I also use a standard car USB adapter in said outlet to power my stuff if needed.
post #6 of 17 Old 02-06-2018, 07:16 AM
The one I have is from Chameleon. I've been a fan but haven't tried any others to compare to... Comes on when the bike is keyed up, and opens a valve for a set duration (you can change the duration) to allow oil to flow.
I'm tied up at the shop tonight but I'll try to grab some photos after work tomorrow if I remember.
post #7 of 17 Old 02-06-2018, 04:47 PM
I added a combo heated gear plug/ battery charging port. I drilled a hole in the left side cover and put a rubber grommet, which holds the plug on the bike side in place. Needed an SAE to heated gear plug adapter for the charging.
post #8 of 17 Old 02-06-2018, 08:10 PM Thread Starter
Looks good. I'm thinking I could do the same thing, just need to make or buy the port.
post #9 of 17 Old 02-08-2018, 07:40 AM
https://www.wristtwisters.com/forums/...1&d=1518104356
2 Wires going to the battery
https://www.wristtwisters.com/forums/...145761&thumb=1
Relay and fuses
https://www.wristtwisters.com/forums/...145769&thumb=1
Terminal block, switched power on the left, constant hot in the middle (really only use for charging) and ground on the right
https://www.wristtwisters.com/forums/...145785&thumb=1
Heated gear fuse (built into the plug I bought)
https://www.wristtwisters.com/forums/...145777&thumb=1
Fuse for USB ports up front
https://www.wristtwisters.com/forums/...145793&thumb=1
Heated Gear plug
https://www.wristtwisters.com/forums/...145801&thumb=1
USB plug with cover
https://www.wristtwisters.com/forums/...145809&thumb=1
USB plug uncovered
I can't figure out how the hell to do thumbnails apparently but I think you can figure out what I'm talking about. Let me know if you have any more questions.
post #10 of 17 Old 02-08-2018, 10:55 AM Thread Starter
What's that orange pad that holds up the seat made of? The seat being lose gets a bit old, how does it hold up when you take the seat on and off?
Is it glued in place?
I like that setup.
post #11 of 17 Old 02-08-2018, 12:19 PM
I stopped my seat from being loose by packing that area where that orange sponge stuff is with thick cardboard. The cardboard I wrapped a heap of times with electrical tape. Its fixed to frame with double sided tape. I bent the two hooks on the side down and wrapped them in tape. I also gave the hook that the front of the seat jams under, near tank, a little bend downwards.
A loose seat gives me the shits!
post #12 of 17 Old 02-09-2018, 06:20 AM
I like that setup.
Just some random rubber we had at work. It has a light adhesive on one side but really is only strong enough to hold the pieces together, it holds up well, but once in a while I'll have to reorient it before I put the seat back on. I tried the cardboard wrapped in tape but it kept getting compressed too much.
post #13 of 17 Old 02-12-2018, 10:53 AM
I don’t know if it is of any interest, but this is how I solved easy access for recharging the starter battery, and I mounted a USB for my phone to get navigation, spotify, phone calls etc without empty the phone battery
I keep the extra cable under the seat with an advisor, telling when to recharge
I got an AGM battery so the charger is in that position.
The USB is connected in a way so I need the ignition to be on to get any power, just to avoid any ”discharge accidents”
This solution has been working very well - never out of power :-)
File Type: jpg 208DF9CA-0E0E-47B1-AAAA-BCA706848C06_1518461312511.jpg (126.0 KB, 18 views)
File Type: jpg 25348B86-8E9D-46B6-AB4F-DE84EA87FBBB_1518461352293.jpg (141.3 KB, 19 views)
File Type: jpg C79FA1D9-5635-4472-8E80-EB5013DCD8B7_1518461392496.jpg (113.2 KB, 19 views)
File Type: jpg AA69DE6A-39F9-400C-ADF4-F7A631C6A3AD_1518461435852.jpg (145.6 KB, 19 views)
File Type: jpg AE47D2E4-1D47-45A7-87CE-900E70B3582E_1518461472554.jpg (169.8 KB, 18 views)
KarlJay likes this.
sugar is offline
post #14 of 17 Old 02-12-2018, 01:20 PM Thread Starter
Looks awesome, what's the brand name on that outlet on the bars, looks like a great setup.
post #15 of 17 Old 02-12-2018, 02:19 PM
You mean the USB?
sugar is offline
post #16 of 17 Old 02-12-2018, 02:25 PM
If so, I have no idea
Guess it is brandless
Foundt it somewhere on the web
sugar is offline
post #17 of 17 Old 02-12-2018, 03:02 PM Thread Starter
I was thinking about having a battery pack inside my tank bag and then just recharge the tank bag that would have the USB ports on it. Just need one that has a quick disconnect to the bike's charging system.
