.. Accel coils - Wrist Twisters
post #1 of 12 Old 06-17-2012, 12:21 PM Thread Starter
brook's Avatar
.. Accel coils
..... can a coil [for the #2 and 3 cylinder] be defective at lower RPM's??...only...
it seems like it clears up at the higher RPM's>>>>> it pulls hard.
With the motor cold, and starting the motor up, I can hold the #2 and 3 header pipes with my hands. but, turning the throttle up, they become hot.
just notice it, the other night after a long fast run. and after that run, I changed the plugs, and have the same results.......thanks
brook is offline
post #2 of 12 Old 06-17-2012, 12:25 PM
Check plugs 2 & 3, could be your Fuel Pressure Regulator.
post #3 of 12 Old 06-17-2012, 04:27 PM
first off what bike are we talking here?
post #4 of 12 Old 06-17-2012, 05:07 PM
Yea, probably should've asked this...
post #5 of 12 Old 06-17-2012, 11:10 PM Thread Starter
brook's Avatar
..... old school, a 86 Yamaha Fj1200.
So, it does not have a fuel pressure regulator.
is there an easy way to check the coils? before I exchange them.
brook is offline
post #6 of 12 Old 06-18-2012, 02:08 AM
I would start with trying to find a FSM for your bike and go through the troubleshooting procedures in it.
post #7 of 12 Old 06-18-2012, 11:14 AM
adamax's Avatar
+1, fsm, this is the way to go.
Gut feeling could be spark plugs, but also could be idle circuit of the carb, especially if it was often parked
adamax is offline
post #8 of 12 Old 06-18-2012, 03:29 PM
ya have the carbs been recently cleaned? if not like stated the slow circuit of the carbs could be blocked.
You could try taking the wires off plugs 2 n 3 one at a time, and hooking to another plug to see if you get spark at lower rpms.... or hook one dem fancy spark plug tester lights inline.
post #9 of 12 Old 06-18-2012, 04:44 PM Thread Starter
brook's Avatar
..... first... thanks for the help guys...... I may have found the problem!!
What I did is, swop the coils, to see if the problem would follow the coil.
and when I pulled the plug wire of off the #3 plug, the little metal boot that connects to the top of the plug, was still on the plug. [broken]
So, I am thinking,.... at low RPM's there is not a good connection [causing the miss].
just ordered, from Dennis Kirk the coil [just to make sure] and wires.
I did call Dyna [ignition], and he said, it is possible that the Dyna ign. could cause that problem..... I have had issues with it before.
and I have had the carbs. apart.
I should receive the new parts, Thursday. Thanks again [time will tell]
brook is offline
post #10 of 12 Old 06-18-2012, 04:50 PM
Glad you found your gremlin!
post #11 of 12 Old 06-18-2012, 09:35 PM Thread Starter
brook's Avatar
..... Thanks
brook is offline
post #12 of 12 Old 06-18-2012, 10:03 PM
yup.... its very possibly to have the spark not be able to bridge some gap at lower rpms (the break in your boot) but at higher rpms with a more powerful spark.... its able to.
