9'r is fueling wierd - Wrist Twisters
post #1 of 9 Old 06-17-2012, 07:07 AM Thread Starter
919>food>beer
Jeef's Avatar
My 919 has some where in the ball park of 80k miles on it, she is maintained well but ridden. I just got back from a 2k mile trip to the gap, a lot of it in the rain. Anyway, I get back to florida it is starts misfiring at low rpm and on deceleration. It seems to be loading with fuel. I checked the fuel pressure reg. and the diaphram is still good on it. Spark plugs were just changed and all are firing. I didn't see any loose vacuum lines or such.
now once I get rolling and on the gas it'll clear up just fine and will tear off... it's just low load-rpm- decel that are issues.
I will be checking my tps again, maybe it got knocked out of position, but other than that I am at a lose. I've ran through two tanks of gas and also pug seafoam in there thinking maybe there was some moisture. but nothing.
Jeef is offline
post #2 of 9 Old 06-17-2012, 07:33 AM
Check your vacuum lines.
post #3 of 9 Old 06-17-2012, 07:37 AM
You checked the pluggs and they didn't look to be fowling or any thing? Do you have a Power Commander? Did you make sure the correct wires were going to the correct pluggs?
07919Dave is offline
post #4 of 9 Old 06-17-2012, 07:41 AM Thread Starter
919>food>beer
Jeef's Avatar
plugs are 2k miles old and didn't see any fouling, plug wires on the 9'r are kinda hard to put on wrong due to the lengths
Jeef is offline
post #5 of 9 Old 06-17-2012, 10:20 AM
check the ground under the tank, as well as the two wires to the coils.
also it could be the fpr... you might have a very very small pinhole leak in the fpr.... and under decel when the throttle is closed vacuum is highest and its very possible that is when its showing its weakness.
post #6 of 9 Old 06-17-2012, 11:43 AM Thread Starter
919>food>beer
Jeef's Avatar
ground is possible... the fpr i hooked up to the miti-vac and it held the vacuum fine, it may be putting out too much fuel though
Jeef is offline
post #7 of 9 Old 06-17-2012, 04:29 PM
naw.... thats the job of the injectors to regulate fuel... the ammount of fuel that they dispense doesnt change all that much with increased or decreased pressure.
post #8 of 9 Old 06-17-2012, 04:53 PM Thread Starter
919>food>beer
Jeef's Avatar
I'm at the Gf's apt tonight, hooked the volt meter to the tps. key on not running it is reading .04 and running it is reading .58 closed throttle... now the thing is, i know that sensor should read .5 with the key on not running, and i believe there should be no difference between running and not... will play with it in my garage tomorrow.
Jeef is offline
post #9 of 9 Old 06-19-2012, 01:51 PM Thread Starter
919>food>beer
Jeef's Avatar
welp... here is the story, I got the tps back to .5v at closed while running and once again the bike is happy and not way over rich. however, I am still baffled as to why it is giving me two different reading when the bike is running and just on. They should be the same. I checked the grounding and it is fine, its not that there is a short between the ecm and tps, as I checked and its the same reading at the ecm.
It runs great now so I guess I should be happy with that...
Jeef is offline
