9er Clutch Cable - Wrist Twisters
post #1 of 26 Old 04-11-2015, 08:13 AM Thread Starter
ewmin3m's Avatar
9er Clutch Cable
Are there any particular specs for the clutch cable? Where do you guys usually get them? Do I have to order directly from Honda or no?
ewmin3m is offline
post #2 of 26 Old 04-11-2015, 08:23 AM
crimedog's Avatar
crimedog is offline
post #3 of 26 Old 04-11-2015, 08:33 AM Thread Starter
ewmin3m's Avatar
Originally Posted by crimedog View Post
Thank you
ewmin3m is offline
post #4 of 26 Old 04-11-2015, 11:22 AM
Call the local dealer .... the exchange isn't great right now and you might be surprised what they can get you a OEM or Motion Pro replacement for.
post #5 of 26 Old 04-11-2015, 11:50 AM Thread Starter
ewmin3m's Avatar
Originally Posted by HeliMech View Post
Call the local dealer .... the exchange isn't great right now and you might be surprised what they can get you a OEM or Motion Pro replacement for. Ian
Yeah I did just that. 30 bucks for OEM cable. But it's coming Thursday therefore no riding this week ((((
ewmin3m is offline
post #6 of 26 Old 04-13-2015, 06:19 PM
alekkas's Avatar
Well, since we are talking about it - I got my bike last fall but it is old (2003) and probably not all that well cared for IMO. 14K miles on it. It feels smooth. I sprayed a little fogging oil in there.
What is the best way to lube?
Is this a side of the road job when I'm in the desert if it goes bad and I have the cable?
Some ride reports:
http://leroylanes.blogspot.com/
On two wheels:
alekkas is offline
post #7 of 26 Old 04-13-2015, 07:56 PM
I use a syringe and long blunt needles... see here
You can always route the new cable next to the old one and zip tie it out of the way. Then it's and easy side of the road job.
post #8 of 26 Old 04-14-2015, 10:50 AM
alekkas's Avatar
Thanks. Got a turkey injector syringe that should work just fine. Just gonna have to remember to replace by Thanksgiving!
Some ride reports:
On two wheels:
alekkas is offline
post #9 of 26 Old 04-14-2015, 02:17 PM
Or just lube the cable with peanut oil.
post #10 of 26 Old 04-14-2015, 03:11 PM
Or in your case, butter.
post #11 of 26 Old 04-14-2015, 06:16 PM
I think mike uses KY on his cable.
post #12 of 26 Old 04-14-2015, 07:46 PM
I tried that but the cable would queef every time I pulled in the clutch.
post #13 of 26 Old 04-14-2015, 08:43 PM
Lol.
post #14 of 26 Old 04-15-2015, 06:55 PM
alekkas's Avatar
Oh my. Was funny for a while and you just HAD to go say that......
Some ride reports:
On two wheels:
alekkas is offline
post #15 of 26 Old 04-17-2015, 11:46 AM
Todi's Avatar
I give up , did not expect this answer
Todi is offline
post #16 of 26 Old 04-17-2015, 01:52 PM
post #17 of 26 Old 04-17-2015, 01:56 PM Thread Starter
ewmin3m's Avatar
i'll be installing the new clutch cable tomorrow. Any tips? Is the service manual explicit enough?
I think i'll lube it before putting it on the bike. Would be easier to manipulate :P
ewmin3m is offline
post #18 of 26 Old 04-17-2015, 02:14 PM
I would not lube a new cable - it comes with a factory dry coating that is resistant to dirt, etc.
Putting lube on it only attracts more dirt and you're more likely to gum it up sooner.
Lubing a dirty/old cable is about the only way to free it up again, but a factory new cable shouldn't need any lube.
post #19 of 26 Old 04-17-2015, 02:17 PM Thread Starter
ewmin3m's Avatar
I would not lube a new cable - it comes with a factory dry coating that is resistant to dirt, etc. Putting lube on it only attracts more dirt and you're more likely to gum it up sooner. Lubing a dirty/old cable is about the only way to free it up again, but a factory new cable shouldn't need any lube.
Sweet. Good to know. Thanks goog :-D
ewmin3m is offline
post #20 of 26 Old 04-17-2015, 05:17 PM
crimedog's Avatar
It's quite easy, just unhook it the lever side, then the other, tape or zip tie the new one to the old one and pull it through for ease of routing.
08 DR-Z400SM
WFOATT
crimedog is offline
post #21 of 26 Old 04-17-2015, 05:18 PM Thread Starter
ewmin3m's Avatar
Nice. I wouldn't have thought of that...
ewmin3m is offline
post #22 of 26 Old 04-17-2015, 05:39 PM
redline919's Avatar
+1 that's a great idea!
redline919 is offline
post #23 of 26 Old 04-17-2015, 06:43 PM
crimedog's Avatar
Can't take the credit, I read it here on WT
08 DR-Z400SM
WFOATT
crimedog is offline
post #24 of 26 Old 04-18-2015, 02:28 PM Thread Starter
ewmin3m's Avatar
So I finally changed the clutch cable... only issue now is that my clutch is slipping... In all gears if I go too hard on the throttle... I'm going to fiddle with the clutch cable adjustments. I'm hopping that's the only issue. :'(
ewmin3m is offline
post #25 of 26 Old 04-18-2015, 02:52 PM Thread Starter
ewmin3m's Avatar
Lol I'm a noob. Had to tighten the clutch cable adjustment thingy. Power wheelie is back :-D
ewmin3m is offline
post #26 of 26 Old 04-18-2015, 03:51 PM
LOL! Glad you figured it out.
