95 Suzuki gsx600 katana won't start?? - Wrist Twisters
post #1 of 10 Old 08-12-2014, 04:29 PM Thread Starter
BikeJockey
I bough this bike yesterday for my brother to ride, everything seemed fine it ran good all day and then the next day it wouldn't start. Key is on killswitch disengaged in neutral, click starter and nothing happens doesn't click nothing at all. Like we're not even clicking the dang button
wonderbread1127 is offline
post #2 of 10 Old 08-12-2014, 04:42 PM
I would start with the battery. Take it out and have it load tested.
post #3 of 10 Old 08-12-2014, 04:48 PM
Here are a few more ideas after you get the battery charged and tested ....
- check the kickstand switch & wiring
- check the kill switch wiring
- Check the main ignition wiring
post #4 of 10 Old 08-12-2014, 04:53 PM Thread Starter
BikeJockey
The battery has a full charge. It'll push start and run. I'll check the kickstand wiring. I wouldn't know how to go about checking the others though
post #5 of 10 Old 08-12-2014, 04:58 PM
Your battery can have a full charge (12V) and still not be able to put out enough current to start the bike if it has a bad cell or something.
post #6 of 10 Old 08-12-2014, 05:11 PM Thread Starter
BikeJockey
That could happen overnight?
post #7 of 10 Old 08-12-2014, 05:17 PM
When my battery went bad, I had ridden the bike the day before and the next day it wouldn't turnover, even having been on the tender all night. I had a new battery on the shelf and popped it in and it started right up. If you are sure it's not the battery, then skip that, but 90% of the "my bike won't start" threads end with a bad battery being the culprit.
In any case, I hope you get it figured out quick. Sucks not being able to ride!
post #8 of 10 Old 08-12-2014, 05:46 PM Thread Starter
BikeJockey
Alright I'll test the output on the battery and the cells, or pop mine from my Honda in it and see.
post #9 of 10 Old 08-12-2014, 06:13 PM Thread Starter
BikeJockey
Battery tested good, still swapped the batteries and didn't work. Some ridiculous wiring all over from previous owner time to trace some wires
post #10 of 10 Old 09-04-2014, 10:10 AM Thread Starter
BikeJockey
Turned out to be clutch wire, clutch cable was frayed and not fully engaging. Now we are waiting for one in the mail
