600r ninja, strange problem. - Wrist Twisters
post #1 of 10 Old 01-27-2015, 03:32 PM Thread Starter
I have a 1986 zx600r ninja, that I've been working on. I tried to sync the carbs but the needles on the tool were jumping back and fourth. I assumed it was timing, but now that I can see all the marks right now it seems to be on time. I'm going to check into more detail on how in time it is. But if it's not on time, what else would make the carbs do that?
xecieon is offline
post #2 of 10 Old 01-27-2015, 03:40 PM Thread Starter
Carbs are rebuildt btw
xecieon is offline
post #3 of 10 Old 01-27-2015, 03:43 PM
Do your gauges have dampers in the air lines?
1972 Honda CL350 "sold"
1981 Honda CB750 Custom "sold"
1983 Honda V45 "sold"
1975 Honda 400F "sold"
1978 Honda 750K "sold"
1969 CT70K0
1980 CBX "sold"
2006 900F 919
SanDogDewey is offline
post #4 of 10 Old 01-27-2015, 03:53 PM Thread Starter
Not going to lie, idk what those are...so I assume not.
xecieon is offline
post #5 of 10 Old 01-27-2015, 03:54 PM
Sounds like an air leak to me.
post #6 of 10 Old 01-27-2015, 04:12 PM Thread Starter
I've check for leaks I don't believe there is one. I'll check again
xecieon is offline
post #7 of 10 Old 01-27-2015, 06:28 PM
I use Carbtune indicators. They have restrictors or dampers in the lines to smooth out the reading.
post #8 of 10 Old 01-27-2015, 07:05 PM Thread Starter
It's an obvious jump back like something is sacking it backwards
xecieon is offline
post #9 of 10 Old 01-31-2015, 05:11 AM
deandeib's Avatar
Sure sounds like there are no restrictors in the lines. Without some restrictors to dampen the oscillation in pressure, the gauges will jump around like hell. In my Motion Pro Sync Pro tool, each tube has a small brass plug with a tiny hole in it. The tiny holes allow the vacuum to build up more slowly to reach its true value. Think of them acting as averaging the oscillations you see when they are not in the lines. Not sure of the size of your vacuum lines but you may be able to buy and use Motion Pro restrictors in you gauges.
deandeib is offline
post #10 of 10 Old 02-09-2015, 04:27 PM
Excellent write up. Now for those that have a ridiculous amount of vacuum gauges ,you can head to your local aquarium store and pick up air line restrictors. I've been using them for over 8 years.
They work perfect and only cost 3 bucks for a dozen
LoopsandLogic is offline
