48k service... - Wrist Twisters
post #1 of 10 Old 06-24-2011, 02:23 PM Thread Starter
MSF blacksheep
Ferris Bueller's Avatar
48k service...
Im approaching 48k fast and wanted to run my service list by you guys to see if i missed anything.
Valve check/adjust
Oil and filter change
Coolant flush
Brake fluid flush
new bearings in wheels, cush drive, swing arm, and steer tube
New spark plugs and wires
Replace fuel filter
Lube cables
New air filter
Shorai battery
silicon vacuum and coolant hoses
fork springs, fluid, valve upgrade
Cam chain and adjusted replacement
Possibly 900rr cam and header swap
Ferris Bueller is offline
post #2 of 10 Old 06-24-2011, 02:29 PM
Valve check/adjust
Coolant flush
Brake fluid flush
Replace fuel filter
Lube cables
New air filter
Shorai battery
Well, I would have changed the oil at say, oh, 5k miles, but that's just me...
post #3 of 10 Old 06-24-2011, 02:32 PM Thread Starter
MSF blacksheep
Yeah, well, mobil 1 4t synthetic is really good oil ... j/k
While im at it i might replace coils too. Anyone ever run aftermarket coils like accell or anything?
post #4 of 10 Old 06-24-2011, 02:53 PM
Total Awards: 17
save your money, there is nothing wrong with your coil.
zaq123 is offline
post #5 of 10 Old 06-24-2011, 03:05 PM
echo echo
post #6 of 10 Old 06-24-2011, 03:11 PM
Stutz's Avatar
Stutz is offline
post #7 of 10 Old 06-24-2011, 03:12 PM
IF you put in such a cam set, I'd be inclined to put adjustable sprockets on so the phasing can be played with.
I've never compared the cam timing to the 919, but suspect the 900 duration, overlap and intake closing will be too extreme for the inlet side of the 919.
So some intake retard might be helpful.
Some more static compression would be good also.
Head planing time.
And seeing as the head is then off, a really nice valve job and port cleanup as well.
You'd likely be further ahead with first oversize pistons with more pop up and a thin Cometic head gasket.
Seriously, going past stock cams sounds like wasted money to me if the intake side is left alone.
post #8 of 10 Old 06-24-2011, 03:54 PM
Personally I say change the oil and ride it.
post #9 of 10 Old 06-24-2011, 04:28 PM
curiousmike's Avatar
+1
curiousmike is offline
post #10 of 10 Old 06-24-2011, 06:12 PM
u gotta go through alotta work for 900RR cams... the sensor pickup for cam phasing is different that the 919 cam.
no point on wires or coils... those parts dont "wear" and a hotter spark means nothing to performance, once you ignite that mixture a longer hotter spark does nothing.
i say inspect bearings n replace as needed, specifically the head n swing arm bearings which probably just need a lil grease... wheel bearings ya i would just go ahead n replace if they havnt been replaced before.
and cam chain, if it looks as if its worn replace, but more than likely its not... no point in tearing down the motor to replace it if its not needed... probably mess more stuff up in the process.
