4 quarts of oil in my 919 - Wrist Twisters
 1Likes
  • 1 Post By K1w1Boy
post #1 of 23 Old 07-12-2015, 04:08 PM Thread Starter
Previous owner told me "about 4 quarts should do it". So, I just did my first oil and filter change and filled it exactly 4 quarts. Then I read that's .2 quarts too much. The bike seems to operate ok, but I'm wondering - did I make a mistake that could mess up my bike? Should I lose the 3 ounces? Or is there a forgivable fudge factor?
fondahonda is offline
post #2 of 23 Old 07-12-2015, 04:26 PM
The last one - there's some leeway. Can you see the sight glass on the rhs side of the engine to check what level the oil has ended up at? That glass tends to represent upper and lower limits, with a line across the centre for "ideal".
If there is some air space above the oil level in the glass when the bike is vertical, even if it's in the upper part of the glass, I would relax about it. If not, you might want to consider getting the oil level down a bit.
K1w1Boy is online now
post #3 of 23 Old 07-12-2015, 04:33 PM
It'll cause your exhaust bracket to crack, JK, you should be fine. I've never had an issue just dumping the whole gallon of Rotella in
voodooridr is online now
post #4 of 23 Old 07-12-2015, 05:11 PM
surplus oil also causes your gauge faces to bubble.
post #5 of 23 Old 07-12-2015, 05:22 PM
...so cruel...
post #6 of 23 Old 07-12-2015, 05:45 PM
Actually, I had my oil cap blow out on the road with my right pant leg being soaked with oil as a result. Also ruined the boots I was wearing. It had a small surplus of oil just like that.
2005 Honda CB919F
2003 Honda CBR954RR (sold)
1990's Suzuki TS200 (sold)
1987 Kawasaki Ninja 750R (sold)
1984 Kawasaki GPz 550 (sold)
Dirt Bikes
op_man1 is offline
post #7 of 23 Old 07-12-2015, 05:58 PM
I use a longer oil filter and 4 qts is perfect.
PAULIBIKER is offline
post #8 of 23 Old 07-12-2015, 06:39 PM Thread Starter
That actually sounds like a good approach, but since the new filter is on, I'll go ahead and drain 2 or 3 ounces. The last thing I need are oily flip flops or bubbly gauges.
post #9 of 23 Old 07-13-2015, 02:18 AM
redline919's Avatar
Flip flops?? Seriously?
redline919 is offline
post #10 of 23 Old 07-13-2015, 04:56 AM
post #11 of 23 Old 07-13-2015, 06:32 AM
Brain stolen again?
Believe none of what you hear and half of what you see.
The owners manual is your friend as it speaks not but conveys much.
Mathew Quigley
post #12 of 23 Old 07-14-2015, 09:34 AM Thread Starter
Naw, just goofin'. Not quite atgatt, but pretty close.
post #13 of 23 Old 07-14-2015, 09:40 AM Thread Starter
Yep. I drained enough oil to see a clear line in the window. I realized that even if a full gallon wasn't going to pose a problem, I'd never stop thinking about it. Better peace of mind than to wonder.
post #14 of 23 Old 07-14-2015, 10:11 AM
Dead Wrong
Effe's Avatar
He is right... You can even download the manual even if you dont have the hardcopy...
Effe is offline
post #15 of 23 Old 07-14-2015, 11:27 AM
I understand that blowouts like the one I got are rare but they are not pleasant. I was lucky not to crash (there really was a lot of oil) and had to make a makeshift cap with newspaper… It was a really cold day and I also happened to leave my phone at home.
The good thing is that given the quantity of oil that blew out, I had just the right amount left…
2005 Honda CB919F
Dirt Bikes
op_man1 is offline
post #16 of 23 Old 07-14-2015, 05:40 PM
redline919's Avatar
Not sure how you would blow an oil cap. Was it a screw on type?
post #17 of 23 Old 07-14-2015, 06:27 PM
Yes, it is a screw on.
It is possible that it was loose or became loose somehow. The guy who does work on my bike said he heard about this happening on occasion but it had not happened to him before. He changed the oil at the same time as he did the valve adjustment. He felt real bad and did make it right.
2005 Honda CB919F
Dirt Bikes
op_man1 is offline
post #18 of 23 Old 07-14-2015, 07:11 PM
My vote is 100% that it came loose - 919 has vibes, and things fall off sometimes.
There should not be enough pressure in the crankcase to blow that cap off.
post #19 of 23 Old 07-14-2015, 07:41 PM
Well you were right about the battery so I'll have to go with that.
2005 Honda CB919F
Dirt Bikes
op_man1 is offline
post #20 of 23 Old 09-05-2015, 08:59 AM
Ayatolla of RoknRolla
Sc0rch's Avatar
that made me go WTF? too...
- 2004 Honda 919
Sc0rch is offline
post #21 of 23 Old 03-07-2020, 08:15 PM
MadMonk
4Liter Oil Sight Glass
Hello Everyone,
Today I did an oil change on my Cb919 2003. As recommended I put 4 quart and checked my sight glass. It was at the recommended level.
I started the motorcycle let it cycle for 2-3 mins. Checked the sight glass again, there was nothing there. I understand the oil circulated went inside the system and there will be depletion compared to the initial stage.
However, Sight glass is empty. I cannot see level of oil there. I just want to make sure I am not doing anything wrong and it is supposed to be empty. The sight glass oil level is for when you fill it up. Is that the correct statement?
Bivas Gelal is offline
post #22 of 23 Old 03-08-2020, 12:50 AM
Give the oil time to drain back to the bottom of the engine, and check it again - it should be 1/2 way up the sight glass when the bike is upright on a level surface.
garyb900 likes this.
post #23 of 23 Old 03-09-2020, 09:34 AM
Isaiah Wright's Avatar
Also, make sure the motorcycle is vertical, not on the side stand when checking the oil.
2003 Honda 919 in Smoke, LED headlight, Renthal Ultra Lows, DanMoto Carbon GP exhaust, CustomLED integrated tail light, LED switchback front signals, PAIR delete, flapper mod.
Isaiah Wright is offline
