04 + Gauge cluster on an 02 919 - Wrist Twisters
post #1 of 7 Old 10-19-2014, 03:32 PM Thread Starter
SGKukov's Avatar
Hey guys,
anyone know if there are any problems putting a later 04+ gauge cluster on an earlier (02) 919?
My casing is cracked along with the tachometer being dented in a bit and sticking, i might just buy a whole new cluster. Wondering if i'll have any problem if i use a newer 04 cluster?
SGKukov is offline
post #2 of 7 Old 10-19-2014, 04:06 PM
Unless I'm forgetting something, they should be identical. To confirm you can hit some parts sites and compare the part numbers.
Ottawa919 is offline
post #3 of 7 Old 10-19-2014, 04:34 PM
You will gain a clock
post #4 of 7 Old 10-19-2014, 04:35 PM
clock and i think... dont quote me.... a B trip meter....
OP everything will plug right in without issue.
post #5 of 7 Old 10-19-2014, 06:12 PM Thread Starter
SGKukov's Avatar
Very nice, thanks a lot for the help guys
SGKukov is offline
post #6 of 7 Old 10-19-2014, 09:45 PM
I'm quoting you.... 1 of the 2 plugs will work. The other plug will not match. 6 pin connector vs 9 pin.
post #7 of 7 Old 10-19-2014, 11:05 PM
It does work, but you'll have to re arrange the pin layout. I did it.
