Touch up paint alternative - Wrist Twisters
post #1 of 6 Old 07-04-2014, 01:05 PM Thread Starter
ErnsteO's Avatar
After doing a little bit of research and trying to find a cheap way to touch up a couple nicks in the paint on my 07 Niner . I settled on this lacquer based nail polish and thought I would share it. At $8 It wasn't exactly cheap but I wanted something that would be a little bit more durable. Also it was difficult to find a good color match with some of the lower quality varieties. This color when mixed well also has that subtle shimmer of the stock paint. Its called "An Affair in Red Square" and it's made by a company called OPI. It was purchased at a local Target store. After having applied it I like how you can build up layers with thin coats and fill in the little dings easily. When mixed well the color is almost exact. Anyhow maybe someone else can find this useful as well.
Attachment 68921
ErnsteO is offline
post #2 of 6 Old 07-04-2014, 05:38 PM
Very cool. Any pics of the touched up areas on the bike?
marylandmike is online now
post #3 of 6 Old 07-05-2014, 10:16 AM Thread Starter
ErnsteO's Avatar
Okay so as it turns out I'm not the best touch up painter so excuse me if it looks a little rough . However like I said I'm pretty happy with the color match. The tailpiece had a little nick just below the a on the radius portion of the tail section. Perhaps if there was a way to sand it a little bit the touch up would look a lot cleaner. It'll do.
ErnsteO is offline
post #4 of 6 Old 07-05-2014, 12:35 PM
That is a pretty good match! Nice work.
post #5 of 6 Old 07-05-2014, 12:39 PM
Total Awards: 17
you should paint your nails and toes with it to match the 9er. That would be hot.
zaq123 is offline
post #6 of 6 Old 07-05-2014, 02:04 PM
Batman
velodesign's Avatar
Cover that with some clear. It will look fine for awhile, but uv does a number on polish. Do a google search. Itll match this week, heat n sun will change that quickly.
velodesign is offline
