Titanium rotor bolts & caliper bolts cheap - Wrist Twisters
post #1 of 6 Old 12-06-2013, 04:41 PM Thread Starter
Just bought these for myself so thought I would share.
Rotor bolts:
M6X20 Titanium Screws 6AL4V Aerospace 4pc Button Head | eBay
Stock rotor size is M6 x 17mm, these are M6 x 20mm & I have checked, there is plenty of space for the bolts to go into the wheel. You will need to buy 3 qty as you will need 12 bolts for the stock wheel. 600F3 wheel, no clue.
Caliper bolts:
M8X35 Titanium Torx Head Screws 4 Pcs 6AL4V Aerospace Grade | eBay
Stock size is M8 X 32mm & these are M8 X 35 mm & I have checked they will fit as there is plenty of space for the bolt to go through. NOTE that these are torx bolts, so a torx bit will be required. I have torx bits so it wasn't a concern for me.
All of the above for a grand total of $26.36 including shipping. Not bad at all.
FYI, these are grade 5 bolts, same as those sold by Pro Bolt.
arshishb is offline
post #2 of 6 Old 12-06-2013, 05:10 PM
pretty sure those are not "torx" head bolts... but more of a 12 point alen variety.... easy to stip... no thanks.
any "weight savings" by going TI will be negated by the fact they are all 3mm longer...
post #3 of 6 Old 12-06-2013, 06:10 PM Thread Starter
So an additional 3mm is going to make them the same weight as their steel counter parts?
As for the striping, well I will be the guinea pig & let you know.
arshishb is offline
post #4 of 6 Old 12-06-2013, 06:51 PM
You can buy the right tool for those.
http://www.ebay.co.uk/bhp/12-point-socket-set
post #5 of 6 Old 12-07-2013, 07:27 PM
More than likely yes... hell even the change between steel and Ti bolts in total is pretty much minimal.
post #6 of 6 Old 12-07-2013, 09:25 PM Thread Starter
I will take the stock bolt & this one to someone who has a decent enough scale & check it out.
From what I understand, ti should be close to 50% less weight. Since these guys are a bit longer, I estimate them to be 40% lighter. Not that even a 100% lighter weight will make a difference on the 919 but I needed new rotor bolts & the amount I spent on these is a LOT less than what some folks spend on fender eliminators
arshishb is offline
